> Bottom Door Rust..., Opinions..
post Apr 27, 2011 - 6:54 PM
StylnPlane
Joined Apr 27, '11
From Grimsby, Ontario.
Need some opinions about this.. Got some pretty serious door rust on the bottom of both driver, and passenger doors.
Get new doors? Or repair them?
post Apr 28, 2011 - 12:35 AM
nwer doors is the easiest way IMO
post Apr 28, 2011 - 12:44 AM
StylnPlane
Joined Apr 27, '11
QUOTE (Batman722 @ Apr 28, 2011 - 12:35 AM) *
Think its hard to find some all power GT-S doors?
post Apr 28, 2011 - 12:46 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
Most celicas have power doors, i agree with batman, new doors is the easiest.
post Apr 28, 2011 - 1:33 AM
StylnPlane
Joined Apr 27, '11
QUOTE (SupraKid @ Apr 28, 2011 - 1:46 AM) *
Alright, ill add that to the list. Door, and a bumper. Thanks!
post Apr 28, 2011 - 1:44 AM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
how much do they run usually, I have rust in the same spots but Im planning on just doing the body work myself
Power in Balance
90 ST coupe- Sold
95 ST hatch- Dead :’(
02 Impreza RS- DD
post Apr 28, 2011 - 1:49 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
Roughly 50$ a piece, just depends where you get them from.
post Apr 28, 2011 - 2:08 AM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
hmm, k, but I think ill learn to do it myself. Being in the North East I should know how to remove rust lol
Power in Balance
90 ST coupe- Sold
02 Impreza RS- DD
post Apr 28, 2011 - 2:46 AM
TheChildOfTheSea
Joined Dec 7, '10
Albany isn't that bad haha! if it's only surface rust, just sand it, apply primer and then oem paint...
post Apr 28, 2011 - 2:48 AM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
eh it has more than surface rust and the previous owners did not care for the car =(
Power in Balance
90 ST coupe- Sold
02 Impreza RS- DD
post Apr 28, 2011 - 6:02 PM
StylnPlane
Joined Apr 27, '11
QUOTE (NYp8tBaller07 @ Apr 28, 2011 - 3:48 AM) *
I hear yah on that one, the dude that owned my car previously thought he was. But only on the outside u know, cleaned the seats, washed the car.
But didnt think of getting right down into the car, where the rust it -.- Now i got gotta put up with it rolleyes.gif
post Apr 28, 2011 - 11:42 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
My cars rusty as well on the doors, on the inside like right below the door panel.
About 2 years ago i took a dremel to it and grinded it off and sprayed a like thick rubber coating on it.
It worked pretty good, but its starting to come back, I guess I gotta give it another round.
My Celica!
post Apr 29, 2011 - 12:34 AM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
QUOTE (jordisonjr @ Apr 29, 2011 - 12:42 AM) *
after you grind it down use some resin then coat it, should last after that
Power in Balance
90 ST coupe- Sold
02 Impreza RS- DD
post Apr 29, 2011 - 10:28 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
What sort of resin?
My Celica!
post Apr 29, 2011 - 11:22 AM
TheChildOfTheSea
Joined Dec 7, '10
epoxy resin used in fiberglass
post Apr 29, 2011 - 11:36 AM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
you also want to make sure you also use a hardener mixed in with the resin or it will take a while
Power in Balance
90 ST coupe- Sold
02 Impreza RS- DD
post Apr 29, 2011 - 1:14 PM
TheChildOfTheSea
Joined Dec 7, '10
^ Like he said
post May 4, 2011 - 12:02 AM
Needles
Joined Nov 18, '10
From montreal
first
u need to took off all the rust from the door outside
unbolt the door took it a part,
(hardest is the wire)
or keep the door wired, and put it upside down on some jack
u will have to grind all the inside of the door whit the grinder until no more rust there
make large pass, for a better job
finish whit metal brush for the little hole
but dont leave any rust, and cover whit any product u want ( putty, fiberglass...)
This post has been edited by Needles: May 4, 2011 - 12:03 AM
Lo-Fi Version Time is now: August 23rd, 2026 - 5:10 PM
