May 10, 2011 - 9:18 AM
Enthusiast ![]() Joined Mar 29, '11 From Bloomington, IN Currently Offline Reputation: 0 (0%) |
I'm trying to change the valve cover gasket, but I'm having a hell of a time getting the cover off. The thing's been slooowly leaking oil, and that's all been building up and creating an adhesive layer. On the 7a, there's just the four acorn nuts that hold the cover on right? I feel like I'm missing something because this thing isn't budging. I tried using c-clamps on the left edge and pulling up, but no luck. Any advice?
May 10, 2011 - 9:23 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
it shouldnt be that hard once you get all the bolts off, did you get the ones where the spark plugs go into?
-------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
May 10, 2011 - 10:34 AM
What do you mean, the spark plug wires? I don't think the plugs need to be taken out.
May 10, 2011 - 6:48 PM
Would it be safe to use some liquid wrench around the joint? I think I just really need to break up this layer of oil to take the cover off.
May 10, 2011 - 7:20 PM
Enthusiast ![]() ![]() Joined Mar 26, '10 From Portsmouth, OH Currently Offline Reputation: 2 (100%) |
when i replaced my timing belt we had to have the valve cover off. i dont remember how many screws there were, but i remember none were hiding or anything. taking plug wires out would probably help, and if it still doesnt come off try GENTLY and CAREFULLY prying with a falt head screw driver where the seal is, since thats what you're replacing anyway
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 15, '10 From The Best Coast Currently Offline Reputation: 12 (100%) |
remove nuts, take out plug wires, hit the valve cover on the sides with a rubber hammer, use the hammer and a flathead screw driver to pry it up
May 10, 2011 - 8:32 PM
Yeah, I'm liking the hammer idea. I'm reluctant to use a screw driver as I don't want to damage the aluminum and just make the leak worse. I'll have to post pics of what this looks like though..must be hella dirty.
May 10, 2011 - 11:21 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
Before you get the whacking, try to use a rubber hammer first!! and you should b ok using a screwdriver just dont try manhandling it too much
May 11, 2011 - 12:32 AM
Enthusiast ![]() ![]() Joined Aug 29, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
i think 4eyedfreek meant did u get the gaskets for where he plugs go aswell as the valve cover gasket
May 11, 2011 - 2:49 PM
Oh, yeah that makes sense. And yes, I got those. I'm on it.
May 14, 2011 - 1:41 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) |
yea, just get the bolts off. anything that can prevent the cover from being removed, remove those as well like brackets or anything. tap on the cover with a mallet, it should loosen eventually lift it up. analyze since Ive never seen a 7afe, 5sfe requires sealant at the halfmoons. make sure you don't overtorque the cover you'll kink the gasket.
May 14, 2011 - 3:08 PM
Alright good advice. Yeah, I got gasket seal to spread around the points where the curves are sharp. Hopefully get this thing done when it stops raining...
May 15, 2011 - 10:02 AM
Enthusiast ![]() Joined Mar 1, '11 From Morgantown, WV Currently Offline Reputation: 0 (0%) |
When I took mine off it was pretty stuck too. Had to tap it with hammer lighlty on the sides to get it off.
May 15, 2011 - 5:35 PM
OK, I must be missing a bolt somewhere then. I had a c-clamp tightened on the left side of it, and I was pulling up with all my herculean strength and it wouldn't give.
May 16, 2011 - 10:16 AM
OK, I must be missing a bolt somewhere then. I had a c-clamp tightened on the left side of it, and I was pulling up with all my herculean strength and it wouldn't give. I don't think there are any hidden bolts. All the tops should be right on top. Some light blows from a hammer or a rubber mallet can be much more effective then pulling with full strength. Tap it a few times upwards on the corner and see if u notice it move. |
May 16, 2011 - 10:27 AM
You do have to move the wiring harness that goes over the timing belt area and you have to remove the throttle cable and bracket that holds it in place. Other than that, once the top 4 bolts come off, it should come right off with a mallet.
May 18, 2011 - 9:12 AM
Ohh...the throttle cable and bracket, didn't think I had to mess with those. Still, that wouldn't make it difficult to remove right? Just inconvenient.
May 18, 2011 - 9:28 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Sep 27, '10 From pittsburgh Currently Offline Reputation: 4 (100%) |
I took mine off yesterday on the way to removing the head. I can assure you atleast on the 5sfe, that there's only 4 of those big ass bolts that go around the spark plug shoots. Also the vacuum line that goes to the intake manifold, but you could remove it with it still connected it would just be a teather.
-------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD -10 F150 Always buying stock wheels... PM me if interested in selling. |
| Lo-Fi Version | Time is now: August 27th, 2026 - 8:20 AM |
