> Walbro 255lph Question
post May 10, 2011 - 10:04 PM
cax_11
Joined Aug 15, '10
From Nevis, West Indies
I have a ST205 Celica, no power mods other than basic intake and exhaust work, will buying a walbro 255lph pump cause me to run rich?
or will I see any improvements in any rpm range?
1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies
post May 10, 2011 - 11:32 PM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
The st205 always run way too rich, so no benefits from putting in a walbro until you start serious modding.
JDM ST205
post May 10, 2011 - 11:54 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
When I upgrade my fuel system I'm going to use the factory pump to feed a surge tank and an external from there to feed the rail
Mike W
269awhp / 273ft-lbs
post May 11, 2011 - 12:58 AM
BriinumsBo
Joined Feb 6, '08
From Latvia
would there be any difference as the stock FPR will still keep the same pressure in rail?
1994 MR2 SW20, 1990 Celica ST185, both 3SGTE
turbo celica | celica club .eu | celica gt4 | imports | Toyota GT 86 | Scion FR-S | Subaru BRZ
post May 11, 2011 - 1:16 AM
delusionz
Joined Feb 11, '08
Intank pump upgrade wont do anything different unless your factory one is worn out or broken. I don't know how many LPH the ST205 factory pump is but it's obviously fit to feed the factory 540cc injectors at standard pressures. Only reason to upgrade intank is if you plan to upgrade your injectors or your factory pump is worn out and want a cool buzzing noise every time the cars running.
Surge tank + external however will give you benefits of preventing fuel starvation during hard cornering and give you a base to upgrade your injectors should you choose to do so in the future.
Mike W
269awhp / 273ft-lbs
post May 11, 2011 - 11:59 PM
cax_11
Joined Aug 15, '10
QUOTE (delusionz @ May 11, 2011 - 1:16 AM) *
Not really building for circuit racing, more of a 1/4 mile car I'm building, so the surge tank won't be of much use here, So then theoretically it should be safe to boost around 14-15psi on the stock CT20b turbo? with no fuel upgrades? I am planning to get a AEM wideband sensor with guage so I can monitor what my fuel is doing, just trying to avoid ever leaning out at all costs.
Nevis, West Indies
post May 12, 2011 - 2:31 AM
BriinumsBo
Joined Feb 6, '08
From Latvia
probably FPR is your answer, im currently looking into installing one myself, since my rev3 3sgte has higher compression (head, pistons) and plugs show some lean fueling biggrin.gif
post May 12, 2011 - 5:38 AM
delusionz
Joined Feb 11, '08
due to the nature of the head and manifold design means #2 and esp #3 cylinders run leaner than 1&4.
but in general theres a blanket rich condition over the entire rev range and load range up to 17psi+
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: August 28th, 2026 - 11:15 PM
