May 22, 2011 - 1:00 PM
Enthusiast Joined Aug 4, '10 From Stanhope, NJ Currently Offline Reputation: 0 (0%) |
I can't figure out what this piece is and it just fell off. |
May 22, 2011 - 1:14 PM
May 22, 2011 - 2:50 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
Thats the Flux Capacitor...
nah j.k seems to be part of the radiator system maybe temp sensor? -------------------- |
May 22, 2011 - 4:02 PM
Enthusiast ![]() ![]() Joined Aug 29, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
lol mine has done that too. its a vacuum line i think?
May 22, 2011 - 6:01 PM
its a vac line, put the hoses back on and zip tie them down
May 22, 2011 - 7:35 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 18, '08 From Houston Currently Offline Reputation: 7 (100%) |
Is that the one with the single wire? If so it's the coolant temp sensor. on some models there is one with a hose that determines water presure/amount; i cant see from the pic.
-------------------- QUOTE (presure2 @ Nov 6, 2010 - 6:16 AM) Via FB: fcuking awsome!!! D-man FTW! Damn D-Man - most impressive. D-Man's post should be a sticky LOL, oh boy, you can always count on D-Man for ridiculously hilarious posts. |
May 22, 2011 - 8:46 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
temp sensor. that sensor reads what you see on your gauge cluster.
-------------------- God made man....
Everything else... Made in China ![]() |
May 23, 2011 - 3:42 PM
May 23, 2011 - 4:03 PM
Does anyone know what the top blue-ish green thing is. I looking it up and the coolant temp sensor is what it connects to.
May 23, 2011 - 7:11 PM
the coolant temp sensor is in the radiator. that's a vac line, trust me, i just did an engine swap not that long ago and I had to hook everything back up. coolant, vac, and wiring because i completely pulled the engine
May 28, 2011 - 2:08 AM
the coolant temp sensor is in the radiator. that's a vac line, trust me, i just did an engine swap not that long ago and I had to hook everything back up. coolant, vac, and wiring because i completely pulled the engine there is another coolant temp sensor in the radiator. that is the ECT sensor for the fans to turn on or off. -------------------- God made man....
May 28, 2011 - 11:52 AM
the circled part is a TVV for emissions I believe, TVV stands for thermal vacuum valve.
May 31, 2011 - 6:15 PM
Enthusiast ![]() Joined Apr 28, '10 From Ft Worth Currently Offline Reputation: 0 (0%) |
its also called bi metallic valve. I broke mine during head swap there pricey to but not having one wiil cost on milage
Jun 1, 2011 - 3:48 AM
Enthusiast ![]() Joined Mar 4, '09 From Ohio Currently Offline Reputation: 2 (100%) |
Looks like no time travel for you...
-------------------- Scraps
Jun 1, 2011 - 4:20 AM
the coolant temp sensor is in the radiator. that's a vac line, trust me, i just did an engine swap not that long ago and I had to hook everything back up. coolant, vac, and wiring because i completely pulled the engine there is another coolant temp sensor in the radiator. that is the ECT sensor for the fans to turn on or off. I have no idea what it is, but it certainly isnt that. the thermo switch is in the bottom of the radiator, stick your hand down there and search for an electrical plug and unplug it, notice your fans will be constantly on. its an electrical plug thats plugged into a bung shaped thing thats screwed in, thats the thermo switch and thats at the bottom of the radiator when facing the front of the car it will be just to the right of the drain bung and outlet hose -------------------- Mike W
Jun 1, 2011 - 5:07 AM
the coolant temp sensor is in the radiator. that's a vac line, trust me, i just did an engine swap not that long ago and I had to hook everything back up. coolant, vac, and wiring because i completely pulled the engine there is another coolant temp sensor in the radiator. that is the ECT sensor for the fans to turn on or off. I have no idea what it is, but it certainly isnt that. the thermo switch is in the bottom of the radiator, stick your hand down there and search for an electrical plug and unplug it, notice your fans will be constantly on. its an electrical plug thats plugged into a bung shaped thing thats screwed in, thats the thermo switch and thats at the bottom of the radiator when facing the front of the car it will be just to the right of the drain bung and outlet hose yeah thats what it is. ECT switch. that is what i just said. it turn on and off the fan. ![]() -------------------- God made man....
Jun 1, 2011 - 5:45 AM
Ok fair enough.
Well mine's here http://www.toyodiy.com/parts/p_J_1996_TOYO...3.html?hl=89428 ![]() SW Temperature in the bottom of the radiator. On the back of my water outlet is the temperature sensor. Wait.. what you showed is in the bottom of the radiator too, are you saying that plug ended up all the way up there? Bizarre. -------------------- Mike W
Jun 1, 2011 - 2:26 PM
Ok fair enough. Well mine's here http://www.toyodiy.com/parts/p_J_1996_TOYO...3.html?hl=89428 ![]() SW Temperature in the bottom of the radiator. On the back of my water outlet is the temperature sensor. Wait.. what you showed is in the bottom of the radiator too, are you saying that plug ended up all the way up there? Bizarre. the sensor on the back of the water outlet is for the temp gauge. the one that OP circled on the picture. edit: can see your pix or the diagram in toyodiy This post has been edited by nics: Jun 1, 2011 - 2:27 PM -------------------- God made man....
| Lo-Fi Version | Time is now: August 27th, 2026 - 7:37 PM |
