> HELP!! Aftermarket Radio install !!, missin/ broken factory brackets
post Jun 2, 2011 - 11:31 PM
JDUB
Joined Jun 5, '08
From Portland, Oregon
hi i just bought a celica and its missing a factory bracket and the other is bent, ive been told i will need these to mount my aftermarket radio and its been tough getting my hands on these brackets
i found this and it says they imulate the brackets, u guys think this will work? or should i go to toyota and get them ordered
http://www.amazon.com/METRA-99-8201-Toyota...l/dp/B0002BEY1S
thanks
post Jun 3, 2011 - 2:21 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
those ones look funny, hold out for a celica wrecking or order them at toyota, shouldnt cost too much
Mike W
269awhp / 273ft-lbs
post Jun 3, 2011 - 9:30 AM
rave2n
Joined May 29, '09
From Gainesville, FL
That link is just a face kit for aftermarket systems.
That kit actually mounts onto the brackets you are speaking of. Hit up a junkyard, definately will be those 2 brackets you need. Just take out the stock unit or aftermarket, and remove the 2 metal plates attached to the unit and there are the brackets you need.
Edit:
After looking at them again, yes they surly do emulate the brackets...
Plastic though..I wouldn't trust a good radio in those.
This post has been edited by rave2n: Jun 3, 2011 - 9:31 AM
post Jun 3, 2011 - 11:25 PM
black13
Joined Oct 11, '06
From calgary
those might be metal but if you want the original, here's a set on ebay.
http://cgi.ebay.ca/1994-1995-1996-1997-199...=item4aaba8b521
post Jun 4, 2011 - 10:02 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
QUOTE (JDUB @ Jun 3, 2011 - 12:31 AM) *
thanks
There's no Celica's at a junkyard or anything like that near your neighborhood. If there is, I'm pretty sure the bracket should still be there. The metal radio bracket really isn't a hot item at junkyards. Lol.
-Ryan
Lo-Fi Version Time is now: July 29th, 2026 - 5:45 AM
