> gt with 3sge swap
post Jun 13, 2011 - 8:46 PM
kaokollaa
Joined Jan 20, '11
From new york
I just did a 3sge swap and i want to kno if i buy a 3sgte i can get extra hp if i pu the 3sge head on the 3sgte? If is possible thanx in advance fir the help
post Jun 15, 2011 - 12:51 AM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
you could do this to gain more hp from the 3sge but downside is you will have to change your pistons to low compression pistons, as the 3sge factory is a high compression engine..i would leave it as is, research some other mods to do. if you want way more power just go with the full 3sgte....be easier in the longrun anyways...
This post has been edited by opie_7afe: Jun 15, 2011 - 12:51 AM
post Jun 16, 2011 - 11:05 PM
Rusty
Joined Nov 5, '07
From New Zealand
you misread opie.
There is a mild gain from swapping the bigger 3SGE cams over to the 3SGTE, otherwise I think they are pretty much the same.
3rd Gen 3S-GE M/T
In: 252deg, 9.8mm lift
Ex: 240deg, 8.2mm lift
3rd Gen 3S-GTE
In: 240deg, 8.7mm lift
Ex: 236deg, 8.2mm lift
You might be able to use the 3SGE shims when you swap the cams over.
post Jun 18, 2011 - 2:16 AM
kaokollaa
Joined Jan 20, '11
From new york
Thanx guys. One las thing and sorry did u know if the 3sge head fits on the 3sgte block
Lo-Fi Version Time is now: September 18th, 2026 - 11:36 PM
