> In regards to Kirk Urethane Motor Mount Inserts, Quick question...
post Jun 21, 2011 - 1:28 AM
Rymaster
Joined Feb 20, '08
From Abingdon, Maryland
(Kirk's Inserts Thread link)
I got the inserts and put them on the new motor mounts I got OEM from Toyota.
The rear inserts looks great cause they lay flush with the bolt hole! (see pictures)
But I fear for the front motor mount with the inserts cause it seems to put up about 1/3 inch higher then the bolt hole itself on the mount...
Is this something I should be concerned about? Or is this just room for the "settling shaking" everyone was talking about on the Kirk Insert buy thread? Everyone claimed to have crazy shaking for the first two weeks or so until the inserts settled in. Or should I grind the front inserts down some?
And yes, in case you ask, I did cut out the extra thin rubber in the middle of the motor mounts since they were new.
Rear motor mount with inserts, fits nicely!
Front motor mount with inserts...not to sure ;(
post Jun 21, 2011 - 3:43 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
your fine
post Jun 21, 2011 - 3:46 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
yes rear one fits perfectly even if the motor mount is new. I had the same problem as you, the front motor mount will not fit in all the way unless your current motor mount is way old and damaged. Your going to have to shave/modify it in order for it too fit on the front motor mount. use google and search next time before posting up a new thread here is the link too the polyurethane motor mounts...
http://www.6gc.net/forums/index.php?showtopic=39891
post Jun 21, 2011 - 5:28 AM
Rymaster
Joined Feb 20, '08
QUOTE (BonzaiCelica @ Jun 21, 2011 - 3:46 AM) *
I already linked to that thread at the top of my first post, I knew it was there. I just wanted a new thread in this section about this to get a quick answer. The other thread was rather....dead.
post Jun 21, 2011 - 6:35 AM
mkernz22
Joined May 10, '10
From MA
I didn't have to shave mine, I just pounded it with a rubber mallet until it was flush. It's hard to tell in the picture, but it looks like you still have a small gap from the lip on the metal to the lip on the insert
post Jun 21, 2011 - 1:08 PM
Fate
Joined Nov 30, '04
From Atlantic City
QUOTE (mkernz22 @ Jun 21, 2011 - 7:35 AM) *
^exactly.
post Jun 21, 2011 - 2:57 PM
Rymaster
Joined Feb 20, '08
I know it looks like that but I don't. It's new mounts so the rubber has a little bit extra sticking out at the top.
I may try and trim it off. It's only the front mount though, I think i'll leave it be and if it's really bad I can just take it back out and shave it down. front mount is an easy job wink.gif
thanks for your input guys
post Jun 21, 2011 - 5:12 PM
BonzaiCelica
Joined Apr 24, '08
Who said reviving an old thread is bad? I do it all the time saves more space on the foruns/server smile.gif
Lo-Fi Version Time is now: September 15th, 2026 - 1:53 PM
