Jul 27, 2011 - 10:27 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Still working on my tranny swap and I've been examining components before I put them back in.
The throw out bearing on my OLD transmission spins freely for about 6-8 seconds, and the throw out bearing on the new (slightly used) transmission stops spinning as soon as I take my hand off it. My question is, which behavior is normal...? I might have gotten brake cleaner on the newer throw out bearing once upon a time when I was cleaning it out... which might be why its acting like this now. :S But I can't remember for sure. -------------------- |
Jul 27, 2011 - 10:30 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
put some pressure on it and spin it with your hand, if it feels rough when you move it toss it and get a new one.
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
Jul 27, 2011 - 10:32 PM
put some pressure on it and spin it with your hand, if it feels rough when you move it toss it and get a new one. Its installed on both transmissions still (attached to the fork)... will this "test" still work, or will I have to pull it off and do it? -------------------- |
Jul 27, 2011 - 10:48 PM
It's not that hard to pull it off the transmission and put it back on, it only clips onto the fork
Jul 27, 2011 - 10:50 PM
It's not that hard to pull it off the transmission and put it back on, it only clips onto the fork beauty - thanks. didn't want to attempt it and make more work for myself. -------------------- |
Jul 28, 2011 - 12:08 PM
a new TO bearing is greased up and should stop spinning immeadiatly, a used one that grease has broken down and worn out so it spins more freely. that means the bearings inside it dont have as much protection and lubrication. you really should replace the TO bearing anytime you change the clutch. for 20-30 bucks its a safe thinig to do
Aug 1, 2011 - 12:16 AM
Enthusiast ![]() Joined Feb 6, '11 From Chicago Currently Offline Reputation: 7 (100%) |
Exactly as Smaay said.
New = Tight seal and lots of grease = resistance = stops spinning fast Old = Worn seal and little to no grease = less resistance = spins longer BAD = deal seal and no grease = Damaged bearing = no spinning |
| Lo-Fi Version | Time is now: May 17th, 2026 - 5:21 PM |
