> using a Gen II 3sgte turbo gasket set on a Gen III?, can I buy the turbo exhaust gasket set for a gen II for my gen III?
post Aug 20, 2011 - 1:36 AM
match220
Joined May 13, '06
From Kaimuki, HI
I went to toyota today and while I was there I priced out the exhaust gasket set for the turbo. $132 here..and think that I can use the Gen II gasket set on the Gen III but I'm not sure. I also didn't see it in gen 3 parts reference. The part number for the whole kit is 04175-74030. does the gasket set fit everything? Oil, water, turbo inlet and DP?
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Aug 20, 2011 - 8:21 AM
nope.
the oil pipe gaskets are diffrent, the dp gasket is diffrent, the exhaust manifold gasket is diffrent, i think the only one that would be the same is the water inlet...lol
post Aug 20, 2011 - 2:36 PM
match220
Joined May 13, '06
From Kaimuki, HI
awe..I was expecting someone to say it works. Where do i get one then?
-Jay
post Aug 21, 2011 - 10:15 PM
Neon90424
Joined Jan 19, '11
From Paraguay, Winchestertonfieldville
I believe this is what you are looking for sir!
http://www.ebay.co.uk/itm/TOYOTA-CELICA-ST...=item4834703001
I had my 3rd gen head gasket set come from Great britain took its time but it was all spot on!
post Aug 22, 2011 - 1:49 AM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (Neon90424 @ Aug 21, 2011 - 5:15 PM) *
kindof, but not quite. The turbo gasket set is sold as a separate kit too. That's the full engine gasket kit with the turbo gaskets. I got a full engine rebuild kit but it never came with the turbo gaskets like that one does, which is weird. I do know toyota sells it separately for the gen II in the MR2.
-Jay
post Aug 22, 2011 - 6:03 AM
Neon90424
Joined Jan 19, '11
I found it on ebay.co.uk searching for Ct20 turbo gasket and found oil water and manifold but no DP gasket...
Lo-Fi Version Time is now: August 22nd, 2026 - 5:29 PM
