Sep 14, 2011 - 5:47 PM
Enthusiast ![]() ![]() Joined Jan 28, '09 From Austin, TX Currently Offline Reputation: 0 (0%) |
Limited Time Ceramic Coating sale!!
Ceramic coating: EMSPowered use the highest quality ceramic coating available. EMSPowered ceramic coating is chemical resistant and color stable (the color does not change after heat cycling, oil and fuel spills do not hurt the coating). It holds up extremely well to extreme temperatures even on the most intense turbo setups. Benefits of Ceramic Coating: * Keeps heat in - By keeping more heat in the pipes you increase exhaust velocity and exhaust energy. On turbo vehicles this allows the turbo to spool quicker and make more power. On naturally aspirated vehicles the higher velocity allows the gas to continue moving out at higher velocity and also results in increased power. * Keeps heat out of the engine bay: By keeping more heat in the pipes and out of the engine bay you keep the other components in your engine bay cooler such as intake pipes, intercooler pipes, the intercoolers themselves, intake manifold, and others. Keeping engine bay and intake temperatures at a minimum will make more power every time on any vehicle whether it is naturally aspirated or turbo charged. * Proper ceramic coating provides a long lasting and beautiful finish that is resistant to rust, chemicals and corrosion. It is not only a performance enhancing coating, but is also provides a pleasant aesthetic upgrade. * Temperature reduction varies between different setups, generally you can expect a temperature reduction of 200-500F on most vehicles. Why EMSPowered Ceramic Coating: At EMSPowered we take ceramic coating to the next level. First we start with a chemical bath to remove any chemicals, oil or grime that is on the surface of the part. Next we sandblast all of the surfaces including the inside of the pipes to remove any corrosion, rust, or other coatings. Then the parts are given another chemical bath to remove all debris and leave a clean surface ready to be coated. After the extensive cleaning and preparation process the part is ceramic coated both INSIDE AND OUT. Finally the part is put into our high temperature oven for it's full cure process. * Many other shops that ceramic coat will coat only the outside of the pipes, this not a complete ceramic coating job in our eyes. All exhaust components need to be coated both inside and out. * Many other shops will use the "air cure" type coatings which cure partially in open air and then the final cure occurs once the part goes through a couple of heat cycles on a running engine. This is not a complete ceramic coating job in our eyes. All parts need to be cured completely and with proper coating materials, not "air cure" coatings. * Many other shops do not put the parts through a proper chemical wash before coating. This causes the coating to prematurely lose it's adhesion to the metal and flake or peel off. Sale prices for common parts (sale ends October 31st, 2011): 4 cylinder manifolds or headers (stock or aftermarket): Normal price: $225/pair SALE PRICE: $100 (56% off) Celica exhausts: This includes coating the entire exhaust, pipes, catalytic converters, mufflers, and tips, we can mask off any part of the exhaust that you want to remain uncoated such as tips. With exhausts we coat inside the pipes but not inside the catalytic converters or mufflers. Normal price: $625 SALE PRICE: $275 (56% off) Turbo Turbine housings (exhaust housing): Normal price: $90 SALE PRICE: $50 (44% off) Turnaround time is 2 days from the time we receive the items from you to the time it is completed and shipped back. Prices do not include return shipping. We charge only actual shipping rates, there are no "handling fees". 1) You ship your items to us. 2) We prep and coat your parts. 3) We bill you the total including return shipping and ship the items back to you ready to bolt on. Payments can be made via MasterCard, Visa, Amex, Discover, or PayPal. We ship worldwide. To get your order started follow these simple steps: 1) Ship your items to the following address. Make sure to leave a slip of paper INSIDE the box with your name/address/phone/email and any specific instructions or notes: EMSPowered 11400 Old Lockhart Rd Building D Creedmoor, TX 78610 2) email sales@emspowered.com to notify us that you are sending your parts in 3) You will receive an email and phone call within 2 days of the parts arriving to submit payment and ship the items back to you. Here are some photos of one of our turbo kits that went through our ceramic coating process.: -------------------- |
Sep 14, 2011 - 5:55 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Dammit! That looks great! Wish you were local for me... :'(
Sep 14, 2011 - 6:09 PM
Dammit! That looks great! Wish you were local for me... :'( We ship worldwide -------------------- |
Sep 14, 2011 - 7:12 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 4, '09 From coral springs florida US Currently Offline Reputation: 21 (100%) |
Dont forget FS
Sep 15, 2011 - 5:58 AM
bak, no trying to be a dick, but how bout taking care of the many guys on mr2oc that have been waiting for parts ect, before posting about your services here anymore.
seriously, the constant excuses and what not over there is old. i understand your a growing buisness, and things happen, but this is a constant thing that goes on with you. http://www.mr2oc.com/showthread.php?t=430782 http://www.mr2oc.com/showthread.php?t=431427 http://www.mr2oc.com/showthread.php?t=424768 http://www.mr2oc.com/showthread.php?t=430941 http://www.mr2oc.com/showthread.php?t=427421 i SERIOUSLY doubt a 2-3 day turnaround time with any service you provide. closed. -------------------- Former Team 5SFTE pro member ;)
| Lo-Fi Version | Time is now: July 6th, 2026 - 1:16 AM |
