Sep 30, 2011 - 2:53 PM
Enthusiast ![]() Joined Jul 27, '11 From calgary Currently Offline Reputation: 0 (0%) |
hey guys, just wondering where to tap in on the gen 3 3sgte WRC for my MBC install. i searched but couldnt find any info on where it goes and what other things i have to plug/unplug for the fuel cut etc. pics would help alot!
thanks1 This post has been edited by 94_gt4: Sep 30, 2011 - 2:54 PM |
Oct 1, 2011 - 9:14 PM
really? no one knows?
Oct 2, 2011 - 7:46 AM
![]() Enthusiast ![]() ![]() Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) |
Hi,
MBC = manuel boost controller? if so do it this way, - there is a air line from the turbo compressor cover to the actuator, in between you must mount the controller - next you have to disable the VSV -> there is a line going out the actuator back to the VSV valve, close this line with a screw or anything else you can use max. safe boost is 1,1bar on a oem engine, do not use the stock boost gauge to adjust the valve, use a good aftermarket one greetz This post has been edited by Sunny: Oct 2, 2011 - 7:48 AM -------------------- |
Oct 2, 2011 - 6:55 PM
Enthusiast ![]() ![]() Joined Aug 15, '10 From Nevis, West Indies Currently Offline Reputation: 0 (0%) |
Hi, MBC = manuel boost controller? if so do it this way, - there is a air line from the turbo compressor cover to the actuator, in between you must mount the controller - next you have to disable the VSV -> there is a line going out the actuator back to the VSV valve, close this line with a screw or anything else you can use max. safe boost is 1,1bar on a oem engine, do not use the stock boost gauge to adjust the valve, use a good aftermarket one greetz Well said -------------------- 1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 1:11 PM |
