Oct 9, 2011 - 1:13 PM
Enthusiast ![]() Joined Nov 13, '10 From Calgary Currently Offline Reputation: 0 (0%) |
hey guys im installing my short shifter today, im following twm's guide on how to do it,
only problem is im getting a little confused at step 12, plz click the link, and if you can help i appreciate it http://www.twmperformance.com/manuals/1994...on%20Manual.pdf |
Oct 9, 2011 - 1:39 PM
If you don't have a vise, just use a pair of pliers. Be careful, though. You don't want to crush the cup. Pliers worked perfectly for me. And remember to grease the ball of the new shifter before you push the cup in!!
-------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Oct 9, 2011 - 2:40 PM
If you don't have a vise, just use a pair of pliers. Be careful, though. You don't want to crush the cup. Pliers worked perfectly for me. And remember to grease the ball of the new shifter before you push the cup in!! ok thanks i actually didnt get to that step, im having troubles getting the clip off with the exacto knife, i cant create a big enough gap to get it off its making me go crazy been at it for 40 mins now |
Oct 9, 2011 - 3:02 PM
![]() Enthusiast ![]() ![]() Joined Apr 20, '11 From College Station, Tx Currently Offline Reputation: 2 (100%) |
I had the same problem. I almost broke my knife. What i did was wedge it open with knife then got a pair of scissors in between it and got it evenly out the just worked from there. and as to getting the cups off the stubs i used a flat head and got it underneath the cup and pushed it off and it came off fairly easy. hope i helped
-Matt -------------------- ![]() |
Oct 9, 2011 - 3:10 PM
I had the same problem. I almost broke my knife. What i did was wedge it open with knife then got a pair of scissors in between it and got it evenly out the just worked from there. and as to getting the cups off the stubs i used a flat head and got it underneath the cup and pushed it off and it came off fairly easy. hope i helped -Matt if i break the clip where do i get a new one , cause it seems like its about to go |
Oct 9, 2011 - 3:37 PM
I had the same problem. I almost broke my knife. What i did was wedge it open with knife then got a pair of scissors in between it and got it evenly out the just worked from there. and as to getting the cups off the stubs i used a flat head and got it underneath the cup and pushed it off and it came off fairly easy. hope i helped -Matt if i break the clip where do i get a new one , cause it seems like its about to go ok got it ! thanks everyone, can someone tell me how to take the clip off the yellow wires , im squeezing but no cigar |
Oct 9, 2011 - 3:44 PM
ok got it ! thanks everyone, can someone tell me how to take the clip off the yellow wires , im squeezing but no cigar Yeah, it wouldn't budge for me either. Instead of trying to open that clip, just pop the clip off of the shift assembly. LOADS easier. -------------------- taking too long to mod since '09
| Lo-Fi Version | Time is now: July 29th, 2026 - 7:35 PM |
