Oct 19, 2011 - 2:07 PM
Enthusiast ![]() ![]() ![]() Joined Nov 27, '09 From Canada Currently Offline Reputation: 4 (100%) |
i just got a tire puncture on one of my tires. They're already pretty much bald so patching it would just be a waste. I'm also too broke to buy a new set of tires. My question is would it be ok to put on 215/60/16 tires on my rims. The OEM ones were 215/50/16. Info will be much appreciated
Oct 19, 2011 - 5:02 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
60 is too tall if you're going to run that wide. Rule of thumb is that if you're going to go taller, you have to go thinner. The contact patch has to change in order to equalize friction to what the OEM specs are.
If you want to run 60 height, run a 195 width. Personally, I'd never run any higher than 55 on a 16" rim. I am running 60 height on my 15" rims and the factory calls for 205/55/R15. So to make up for that, I am running 195 width and it works fine. Fills the wheel well a little more, but it's not too bad. Good for winter tires to have a smaller width anyway. Summer tires I run 215/45/R17. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
Oct 19, 2011 - 7:32 PM
Enthusiast ![]() ![]() Joined Dec 30, '09 From Wilmington, NC Currently Offline Reputation: 1 (100%) |
Doesn't answer the question, but is really helpful when you start looking into to width vs height etc...
http://www.miata.net/garage/tirecalc.html |
| Lo-Fi Version | Time is now: August 28th, 2026 - 1:41 AM |
