Nov 26, 2011 - 12:14 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
hey guys i need some advice here, im running a Stage 4 Comp 6 puck sprung clutch and it catches very low ever since it was installed after i did my swap. now that the car is off the road i have a lil more time to pluck away at the small issues that need to be delt with.
ive tried to bleed the clutch several times and it still catches low, (right at the floor) literally.. i have the clutch held to the floor and i lift not even half an inch and it grabs, is it supposed to be like that? is that just how this clutch is? the clutch itself is fine, i checked it when i replaced my tranny after a 1000miles on the swap lol. the clutch engages and shifts properly its just very low and its annouying at times espically when in traffic. any advice or other options would be helpful, thank you -------------------- st205 powered ss3 coupe
Nov 27, 2011 - 9:37 AM
make sure the clutch is completely broken in, then adjust the pedal. (there is a setup under there to adjust where the pedal catches.
Nov 27, 2011 - 9:47 AM
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
^^Like Manny said, and here is how to do it.
Nov 27, 2011 - 11:21 PM
thats what im going to have to do, i was trying to avoid messing with the pedal but ive tried everything else and the clutch has about 6k on it so i kno its broken in. thanks for the tip guys.
Nov 28, 2011 - 11:13 AM
personally i like having the clutch grab right off the floor
Nov 29, 2011 - 4:00 PM
personally i like having the clutch grab right off the floor its alright at times i guess, i mean ive gotten used to it tho. i feel like if it was raised up a little it would give me quicker ingagements. -------------------- st205 powered ss3 coupe
| Lo-Fi Version | Time is now: August 25th, 2026 - 5:52 AM |
