> R/C Top Mount, Power?
post Nov 30, 2011 - 10:17 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
Hey guys, I tried searching the threads but I came up with no answer. If there's a topic about this already, I apologize in advance. I was looking to see what is the most amount of power that a 3SGTE (3rd gen) has made with a radiator cooled top mount? I am planning on getting one (trying not to display that my car is turbo'd by changing my front mount) and I was just curious. By the way, that's not the only reason I want to change to top mount, I have other reasons which I will not bore you all with. I just wanted to know how much power the radiator cooled top mount can keep up with. Also, any info on this top mount, such as pro's & con's, would be greatly appreciated.
EDIT: Also, this may be a dumb question but would the top mount fit with the oem hood, or would I have to upgrade to the GT4?
-Thank you for your time, Ryan
This post has been edited by str8thugginit4ya: Nov 30, 2011 - 10:32 AM
post Nov 30, 2011 - 1:11 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
long time ago i was in contact with a guy from denmark, he used the TTE group a setup, iirc he drives with ~700HP (DIN)
he compared the setup with a HKS type R & S air to air setup and found that nothing was able to cool better as the TTE one,
with a faster spool up of ~400rpm (no pipeways -> less pressure drop with the tmic system)
the TTE tmic has one more row (8 instead of 7 rows, overall ~ 1 cm higher), internal air baffels, and a higher water backpressure -> possible a different radiator design
i think you need a GT4 hood.....
hope it helps
greetz
This post has been edited by Sunny: Nov 30, 2011 - 1:23 PM
KEEP COOL UNDER PRESSURE
post Nov 30, 2011 - 3:24 PM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
^^^Thanks a lot. I'm assuming "TTE" stands for Toyota Team Europe? Not too sure. Ok, I'll have to find out 100% if I need the GT4 front for the top mount to fit.
-Thanks again, Ryan
post Nov 30, 2011 - 3:43 PM
Sunny
Joined Nov 15, '10
From Austria
Hi,
that is correct, it is the team that build the toyota rally cars (years ago)
greetz
This post has been edited by Sunny: Nov 30, 2011 - 3:43 PM
Lo-Fi Version Time is now: September 17th, 2026 - 7:50 PM
