> re gearing s54, has anyone done it?
post Jan 8, 2012 - 11:42 PM
99gt3sge
Joined Jun 7, '11
From so cal
i have red some of the threads, i was wondering if anyone has changed out their fifth gear from a s54 to s51? was wondering if the rpm drop was drastic? also if anyone has completly re-geared their s54 from first thru fifth? the reason i ask is because my third gear grinds and the front shaft bearings sounds like its gone bad already. so since im going to crack it open was wondering if i can re gear it. aside from finding a lsd for it.
post Jan 9, 2012 - 3:44 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE (99gt3sge @ Jan 8, 2012 - 11:42 PM) *
regearing the whole s54 transmission wouldn't be ideal. Unless your racing and you wanted a closer gears. You could swap in the 5th gear from the s51 into the s54 if you'd wanted to for lower rpm at cruising speeds.
good luck finding a s51 transmission thats in good condition. those transmission came in late 80's camry's.
post Jan 10, 2012 - 1:23 AM
99gt3sge
Joined Jun 7, '11
From so cal
were those the camrys that came with the 1sfe?
post Jan 10, 2012 - 2:58 AM
BonzaiCelica
Joined Apr 24, '08
QUOTE (99gt3sge @ Jan 10, 2012 - 1:23 AM) *
hmm it beats me... I'm going to sell my current s54 transmission in a month (without a final drive in it) that has about a little over 100k miles on it. It shifts fairly well I say. Let me know if your interested.
post Jan 10, 2012 - 8:44 AM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
I considered swapping 5th gear in my s54 a few years ago. Watch Craigslist (using searchtempest.com) for wrecked Camry's being parted out. Ones with front end damage are best because if the bellhousing is broken, you'll most likely get the trans for next to nothing.
You'll find this link helpful.
http://www.mr2.com/forums/v6-owners-group/...s-pics-too.html
Make sure you read post #10 and post #13 to clarify which years Camry you want to be searching for.
post Jan 10, 2012 - 10:10 AM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
Using the same gearing calculator mentioned in the link I posted earlier, I made a chart and overlaid the two (using the S54's 4.176 final drive) in order to show you the how the gearing would look if you were to swap an S51 5th gear into your S54 transmission (with the stock tire size)
Here is the S54:
Here is the S51:
S51 5th gearset in the S54:
Overlaid comparison of 5th gears in the S54:
Edited to clarify final drive used.
This post has been edited by AMCMoe: Jan 10, 2012 - 10:17 AM
post Jan 10, 2012 - 11:41 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
so a 300 rpm drop @ 70 basically
nice difference
post Jan 10, 2012 - 1:36 PM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
About 375rpm drop at 70mph with stock size tires. Calculated it'll be ~3008rpm with the S51/S54 hybrid instead of ~3374 with the S54 using a calculator from http://www.snoman.com/HTML/axlecalc_5a.html
post Jan 10, 2012 - 1:54 PM
mkernz22
Joined May 10, '10
From MA
now here's the question. Will the S51 swap onto a 5s no problem? Will the shift cables, axles, and etc be a perfect fit?
post Jan 10, 2012 - 1:56 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
QUOTE (mkernz22 @ Jan 10, 2012 - 1:54 PM) *
From what I've read on mr2.com they do swap right in No problem
94 st hatch my daily driver
n
post Jan 10, 2012 - 6:20 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
you can swap ONLY the 5th gear.
which will NOT require pulling the trans out
Basically it should be:
remove driver wheel
drain fluid
remove 5th gear cover
remove 5th gea (will need a gear.pulley puller)
install s51 5th gear
reinstall cover
add fluid
install wheel
post Jan 11, 2012 - 12:39 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (stephen_lee @ Jan 10, 2012 - 6:20 PM) *
remove driver wheel
drain fluid
reinstall cover
add fluid
install wheel
so you can't swap the whole transmission over?
it looks exactly the same as the s54. saw one on ebay
post Jan 11, 2012 - 9:47 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
oh ya you can lol but its more work lol.
post May 6, 2012 - 9:46 PM
99gt3sge
Joined Jun 7, '11
From so cal
I kkow is an old post but, today I bought two transmissions one from a 87 Camry and the other from a 5th Gen, and the tooth count on both are different by two teeth. How do I know which one would give me the better 5th for a taller gear.
post May 6, 2012 - 9:51 PM
mkernz22
Joined May 10, '10
From MA
I believe it should be the gear with more teeth because that would make it longer, whereas less teeth would make it shorter
post May 7, 2012 - 3:21 AM
BonzaiCelica
Joined Apr 24, '08
get the final drive from a euro s54 transmission. longer gears all across. just removed weight from the car, that would be optimal.
post May 10, 2012 - 12:32 AM
99gt3sge
Joined Jun 7, '11
From so cal
I swapped the fifth of the Camry to my 3rd Gen s54 and it worked it dropped my rpms by 1k. Now I can cruise it on 5th. But the only thing I didn't like was that that 5th gear uses a single syncro and my other used a double syncro.
post May 10, 2012 - 3:24 AM
BonzaiCelica
Joined Apr 24, '08
QUOTE (99gt3sge @ May 10, 2012 - 12:32 AM) *
what size tires do you have??
post May 10, 2012 - 7:05 AM
pgiorgio
Joined Feb 24, '11
From mass
I just did it on my 95 Beams vert. At 65 mph the rpms dropped from 3200 to about 2800. I'm running 16 inch tires. Also, after one tank of gas, driving carefuly, I got 35 mpg vs 31 mpg with old set up.
post May 10, 2012 - 10:56 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
QUOTE (99gt3sge @ May 10, 2012 - 1:32 AM) *
u take any pictures?
Lo-Fi Version Time is now: August 26th, 2026 - 2:17 AM
