> installed door subs an doors rattle, what will make it stop
post Jan 10, 2012 - 1:54 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
I installed 8 inch subs in my doors an of course they rattle like crazy now
Would that stick on sound deadner help or does anyone have a low Buck solution to the problem
Thanks in advance
94 st hatch my daily driver
n
post Jan 11, 2012 - 9:04 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Depends what is rattling..Figure that out haha. My money is on the exterior door handle.
post Jan 11, 2012 - 9:13 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Lol thanks honestly it seems like it's the whole door vibrating
Causing the rattle sound
n
post Jan 11, 2012 - 9:17 PM
azian_advanced
Joined Apr 18, '05
From Calgary
x2 on finding out what exactly is making the noise.
if you press against the door panel from the inside, does it still rattle? i found mine rattled along the top of the door panel. the metal piece that extends along the top of the interior door panel that hooks onto the metal door frame, well that so-called hook piece widens over time as you close the door shut. it just needed to be bent back tighter to secure the panel on the door frame. otherwise, other common sources for vibration on the door is the door handle (just bend the bracket that secures the 10mm bolt further inwards) and the plastic pivot on the metal door panel that connects the mechanical rods for the latch and manual door lock (a thick piece of foam padding kept it pressed between the door panel and metal door frame). my doors didn't rattle after that even on the highest volume.
This post has been edited by azian_advanced: Jan 11, 2012 - 9:18 PM
post Jan 11, 2012 - 10:48 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ok so going through an making sure everything is good an tight should help
an if i push on the door skin it stops so I'm guessing that's door handle then
n
post Jan 12, 2012 - 3:03 AM
Cuts_the_Pilot
Joined Dec 15, '02
From Tasmania(Australia)
Go to a car audio place and buy some dynamat, i'm not sure what it's called in the states but its a sound deadoning matt, its a thick heavy matt, sicky on one side and thin alloy sheet on the other. Put a large section directly behind the woofer (on the INSIDE of the OUTER door skin) and on the INSIDE of the INNER door skin.
GRX133 Toyota Mark X 350s
post Jan 12, 2012 - 10:22 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
OK
I'll try to pick some up soon
I didn't think with a 300 Watt sub is would be as bad as it is
n
post Jan 12, 2012 - 2:27 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (kurt95gt @ Jan 12, 2012 - 10:22 AM) *
OK
My doors have rattles just from my exhaust. I just hit the door and it goes away most of the time haha
post Jan 12, 2012 - 5:33 PM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (mkernz22 @ Jan 12, 2012 - 3:27 PM) *
laugh.gif Both my cellies had rattles on the doors. I planned on finding each one, and addressing it, but usally I just turned the bass up enough I couldn't hear it =P
post Jan 12, 2012 - 7:17 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
that's probably what ill be doing for awhile
n
Lo-Fi Version Time is now: September 1st, 2026 - 1:27 PM
