Feb 27, 2012 - 8:47 PM
Enthusiast ![]() ![]() Joined Mar 8, '10 From Great White North Currently Offline Reputation: 3 (100%) |
QUOTE ("klue") Lots of parts for sale, deals only if your getting multiple items. If you need just one part instead of the whole assembly message me IE: TPS sensor from a TB ![]() st165 valve cover 75 st185 valve cover 50 5sfe valve cover 30 3sgte oil pans - 40 5sfe oil pan - 35 st205 alternator - 100 st205 coolant overflow - 40 st205 starter 75 st185 alternator - 75 st185 starter - 50 AC compressors - 50 3sge overflow - 30 ![]() Trans cooler - 40 trans shifting mechanism - 50 anything else in the picture 2 for 20 ![]() 3sgte TB - 50 3sge TB(89) - 40 5sfe TB - 40 turbo to ic coupler - 5 IC to TB coupler - 25 ![]() st165 coil - 60 st165 rotor- 5 st165 cap - 15 st185 coil - 50 st185 rotor -5 st185 cap - 15 st185 wire set - 50 st185 splitfire wire set - 110 complete low mile dizzy no leaks - 150 ![]() AFMS are working perfectly st165 AFM - 100 ST185 AFM - 100 ST185 full intake set up (AFM, air box, good intake pipe, KnN filter) - 200 ![]() |
| Lo-Fi Version | Time is now: June 23rd, 2026 - 6:31 PM |
