> went to the track for the first time, and broke somethin....
post Mar 13, 2012 - 11:47 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
This past weekend I went to a quarter mile dragstrip 1.5 hour away from my house for the first time since I swapped.
I ran a 14.6 against my good friend in the genesis coupe. he ran a 15.4. I was on low boost 8psi stock boost for me is 15psi still breaking motor in, wont turn it up until 3k miles whats funny is that with my first 4th gen swap, i ran a 14.2 on 15psi! i had crappy 205 40 tires, and spun ALOT. that must be the MAIN reason why i ran so slow...
i decided to do a 3rd run and broke something related to the drive train.... FML. I'm thinking its either a broken clutch or my axle popped out. I havent had a chance to get under the car as work has been kicking my butt!!
Symptoms that make me think I broke something related to the clutch (possibly disc) is that
1. car will not stall out when I put it in gear and release clutch
2. I can shift through all gears while the car is still on WITHOUT pressing the clutch (reverse will grind a little)
when i got home and unloaded the car from a trailer borrowed from a friend, we found that tranny fluid was on the ground. My friend says that the axle probably popped out, which may be true because i noticed that there was axle grease on the subframe.
Hopefully its just a messed up axle!! i REALLY dont want to remove that tranny!!
if anyone has any suggestions please feel free to add! (video of my race is on facebook in the 6gc group)
my specs for the drive train are: s54 tranny, comp 6 puck clutch gt axles.
post Mar 14, 2012 - 5:28 AM
richee3
Joined Jun 29, '08
From Denver
Hopefully it's just an axle, nothing more. Knowing the luck you've had so far, I'd hate to see it be anything more.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 14, 2012 - 8:51 AM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (easternpiro1 @ Mar 13, 2012 - 11:47 PM) *
Yeaaa, that right there says more then axle issue. Specially #2
post Mar 14, 2012 - 9:41 AM
you might have busted the CV. but until you get under there and find out for sure, its just speculation
post Mar 19, 2012 - 10:19 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
GOOD NEWS!!!! it was the axle!!! THANK GOD! apparently i launched too hard, and it snapped the axle SMOOTH. about an inch and a half of the axle got stuck in the tranny, had to push it out! will post pix later...
i was only at 8lbs.... thats kind of concerning.... but ah well...
post Mar 20, 2012 - 12:20 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
broken piece of axle stuck in trans
gonna put the tranny fluid in, and see how it runs! still go this weird grease as if the CV boot busted on the passenger side, but couldnt find any leaks
post Mar 20, 2012 - 9:05 AM
Culpable04
Joined Apr 17, '06
From New Jersey
you should buy upgraded axles if you are sticking with the S54, the OEM axles will not take abusive launches too well, we've seen 4 trans with snapped axles in the last year alone. none E153.
or the cheaper way, launch better lol, if you are snapping axles, it means you were also losing traction if the tires were to spin, you need smoother launch, less power when launching = more traction, and once you are moving you can apply more power steadly.
I'd still upgrade the axles tho.
post Mar 20, 2012 - 10:52 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
how'd u push it out from the other side? was there a bar in the way?
post Mar 20, 2012 - 11:43 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
You and cars don't get along. I suggest you just take up cross stitching instead. Much safer for you.
**** Photobucket
post Mar 20, 2012 - 11:54 AM
wow thats an awesome break. did you get the broken part out of the diff?
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE (95CelicaST @ Mar 20, 2012 - 11:43 AM) *
doesnt that require needles ?
lego sounds safer, you can build one of those gaint helicopter I've seen oat walmart out of legos
post Mar 20, 2012 - 12:07 PM
95CelicaST
Joined Feb 5, '05
QUOTE (Culpable04 @ Mar 20, 2012 - 9:54 AM) *
True life. Maybe sock puppets is his true calling.
**** Photobucket
post Mar 20, 2012 - 11:32 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (Culpable04 @ Mar 20, 2012 - 10:05 AM) *
^^^TRUTH but here's the weird thing.... I was only at 8psi! it was my 2nd time EVER at a drag strip. so i def need to get some practice in!
QUOTE (95CelicaST @ Mar 20, 2012 - 12:43 PM) *
i tried... i almost put an eye out! lol
QUOTE (Smaay @ Mar 20, 2012 - 12:54 PM) *
we tried to get it out with a magnet first but that didnt work, then we had to remove the driver side axle and push it out from there
Lo-Fi Version Time is now: August 11th, 2026 - 3:36 PM
