> Strut Knocking Sound, In the rear
post Mar 26, 2012 - 3:13 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
I've recently changed out my struts with KYB Gr2's and also replaced the strut mounts all around
(mounts looked like this, but ordered kyb http://www.ebay.ca/itm/OEM-Replacement-Fro...=item2c5f3c522c )
However, in the rear, I am still getting a knocking sound in the rear, as if the struts are blown but everything is all new.
Everythings been put in correctly.
Is there another part that needs to be replaced when replacing the strut mounts as well?
Or could there be something else causing this sound?
I tried searching but nothing came up.
My Celica!
post Mar 26, 2012 - 3:40 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
The only knocking sound Ive had in the rear was my sway bar bushings, they were pretty much shot and over bumps would make a slight knock sound. I pretty much narrowed it down to those when I had my car jacked up and moved the bar around by hand. Replaced them recently and knocking sound went away.
post Mar 26, 2012 - 3:49 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Are those the ones that wrap completely around the bar?
Ill give that a look, because it seems to only knock when I hit a bump thats not even. If I hit a crack that goes right across the road and botch wheels hit at the same time it doesn't knowck, but if they hit unevenly it does knock, so Ill have a look at that.
My Celica!
post Mar 28, 2012 - 3:44 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Bump, Any other suggestions?
My Celica!
post Mar 28, 2012 - 4:43 PM
toyotatech3
Joined Jul 30, '04
From colorado
check the sway bar links
post Mar 28, 2012 - 5:11 PM
Redmann813
Joined Jul 20, '11
From Houston tx
I have the same symptoms too but i thought it was strut mounts. My suspension technique sway bar also moves side to side when jacked up, thought that was normal. My end links are new though.
post Mar 28, 2012 - 10:20 PM
mkernz22
Joined May 10, '10
From MA
it's the sway bar bushings. I have the same problem with my car. if your struts were bad, the bad end would be really loose and bounce around over bumps.
post Mar 29, 2012 - 8:02 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Yea struts and moutns are new, as well as the endlinks are relatively new as well.
However there was some various parts in the strut mount, such as bearings and a couple other small parts that didn't get replaced when changing the mounts so I thought maybe that had something to do with it.
Ill have to have a look at the sway bar bushings this weekend though when I got a chance since more than one person is leaning on that.
My Celica!
post Mar 29, 2012 - 10:55 AM
mkernz22
Joined May 10, '10
From MA
You can't really tell anything from just looking at them because they look normal. Just from being so old they have loosened up a bit and don't hold as well anymore
post Mar 29, 2012 - 10:59 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Is there anything else it could possibly be either than the sway bar bushings?
My Celica!
post Mar 29, 2012 - 5:13 PM
199celica
Joined Jul 29, '11
From chino, Ca
not to steal your thread man but i just put in the same set up but my sound is coming from the front did you have any problems with the front knocking?
post Mar 29, 2012 - 8:22 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
No, you probably didn't line the mounts up with the arrow to the outisde.
And I know thats not my issue cause I had to take them both out in the rear to re allign the strut moutns cause they were wrong the first time.
My Celica!
post Mar 29, 2012 - 8:45 PM
bruiseboy2
Joined Mar 1, '12
I recently did the struts on my car as well and had a similar noise. What it ended up being on my car, which is a coupe not a hatchback, was that the hinge for the trunk was slightly loose, and whenever you went over a bump or pothole, the trunk would make that similar blown strut knock sound. Hope this helps, ended up just throwing some white lithium grease on the bracket and tightened up the bolts.
post Mar 29, 2012 - 9:54 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Never thought of that. Ill take a look at that as well.
Would be an easy thing to over look and would save some cash as well haha.
Thanks.
My Celica!
post Mar 30, 2012 - 5:13 PM
199celica
Joined Jul 29, '11
From chino, Ca
thanks jordisonjr i forgot they had to be pointed a certain way my cv boot tore on me when i removed it so i had to rush around thanks man.
post Mar 30, 2012 - 10:18 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
No problem.
My Celica!
post Mar 31, 2012 - 1:43 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The sway bar bushings are a cheap and easy item to fix or replace. Given the age of the car, you're likely to damage them when you remove them anyway, even if they weren't damaged before. When you do replace them, I suggest a little non-petroleum based oil to help get them into place. I found vegetable oil worked well.
That said, the dreaded rear-end clunk has another common suspect: the suspension arm bushings. The suspension arms are the slender rods which run in pairs, two arms to each wheel, from the centre of the chassis. It's not at all uncommon for the bushings to fail enough for the arm to produce a clunk as it works up and down. Typically, it's the inboard bushing of the No. 2 arms, which are the rearmost of each pair. Get the car up in the air, and work the arms. I could produce a clunk simply by hitting my fist on the arm with the faulty bushing.
post Mar 31, 2012 - 7:48 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Did you have similar issues with only cluncking when hitting bumps unevenly with the wheels?
Ill have to take a look at those trailings arms as well, but I'm hoping those are not the issues. Thanks for the input.
My Celica!
post Apr 1, 2012 - 12:49 PM
mkernz22
Joined May 10, '10
From MA
Well I know for a fact that my clunking was because of my sway bar bushings. I was replacing my endlinks and moved the sway bar around and it made the same clunking that I would hear while I drive. I'm probably going to replace them in the summer when I drop the gas tank, and I might even just get ST sway bars if I have everything off.
post Apr 1, 2012 - 1:44 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
I took a look yesturday at my sway bar bushings.
They were a little cracked, but not too bad, and there was also a little bit of space between the sway bar and the hole in the bushing, maybe a mm or 2.
Also, I tried to pry the sway bar and wiggle the bar to recreate the sound, and couldn't get it. Also stood in the trunk on one side, and tried to bounce teh car up and down while someone below listened for the sound, and also couldn't reproduce the sound.
Endlinkswere tight as well as the three top nuts on the strut mounts were tight as well, so those can be ruled out.
My Celica!
Lo-Fi Version Time is now: August 4th, 2026 - 10:07 AM
