> How big should i make my exhaust piping?, 95 Celica ST
post Apr 4, 2012 - 2:30 PM
WhipCreamCelica
Joined Feb 1, '12
From The Colony, TX
I have an invidia n1 exhaust muffler on stock piping, i was planning on going to a muffler shop and getting my catback piping in 2.5", and my down tube for my headers in 2", would these measurements be correct for my 95 st??? thank you, i need to know, i also have stock headers right now,
post Apr 4, 2012 - 2:57 PM
Box
Joined Feb 23, '12
From Warrior, AL
Wondering the same myself. Was planning on having exhaust redone from behind the second O2 senor and back. Remove cat, resonator, and stock muffler and stay with the stock 2" diameter and put a Magnaflow muffler on. Provided aren't going to do excessive modding to the engine I'd think 2" would be enough. I'm personally afraid of going too big, and having a bad sound. Hopefully someone that's been there and done that, can chime in.
2001 Miata LS 5-speed
post Apr 4, 2012 - 3:11 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
2.25" max
**** Photobucket
post Apr 4, 2012 - 3:13 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE (95CelicaST @ Apr 4, 2012 - 3:11 PM) *
2.25" max
agreed especially on such a low ouput hp engine above 200hp i'd then go with 2.36"
This post has been edited by BonzaiCelica: Oct 27, 2013 - 9:27 PM
post Apr 4, 2012 - 4:38 PM
azian_advanced
Joined Apr 18, '05
From Calgary
post Apr 4, 2012 - 4:49 PM
WhipCreamCelica
Joined Feb 1, '12
From The Colony, TX
Thanks for the info everyone! 2" it is!
post Apr 4, 2012 - 5:09 PM
6gcpr
Joined Apr 29, '11
From Puerto Rico
My dd 95 corolla has the 7afe with intake and obx header and i did all the piping from the header to the muffler 2.5 and the car moves great and sound's fantastic.
1980 mitsubishi champ- stolen
1995 toyota corolla. - daily driver
1994 toyota celica gt. - project car
1984 honda civic hatch - wifes
post Apr 4, 2012 - 5:48 PM
BonzaiCelica
Joined Apr 24, '08
Celica SS-III and Integra Type R DC2 both have 57mm exhaust piping.
post Apr 4, 2012 - 6:03 PM
trdproven
Joined Aug 2, '05
From Guam
i'd still go with 2.25
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 6, 2012 - 1:46 PM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
QUOTE (Box @ Apr 4, 2012 - 3:57 PM) *
I wouldnt remove your cat, its pointless your not putting out the power that requires a cat removal. A resonator doesn't restrict anything it just reduces exhaust noise.
QUOTE (6gcpr @ Apr 4, 2012 - 6:09 PM) *
It's the mod effect that you think the car is faster but it's not really. You cant feel or notice a hp gain from an exhaust because all you're doing is freeing up the path, you're not intaking more air, which means you're not pushing anymore out.
A car works like a vacuum, you have X amount coming in and X amount coming out, it doesn't matter how large the path is you can only push out as much as you're taking in.
This post has been edited by hatchy_gt-s: Apr 6, 2012 - 1:49 PM
post Apr 6, 2012 - 4:47 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (hatchy_gt-s @ Apr 6, 2012 - 1:46 PM) *
It's the secondary cat. Everything behind the first cat and O2 sensors I want to replace. Doesn't cost that much more than just adding a muffler at my local exhaust shop. So, figured what the Hell, might as well. Plus I'll make money from scrapping the cat. tongue.gif
post Apr 6, 2012 - 5:28 PM
6gcpr
Joined Apr 29, '11
From Puerto Rico
QUOTE (hatchy_gt-s @ Apr 6, 2012 - 2:46 PM) *
Well, i personally feel the car more light and nimble than before. I know i gain almost nothing of hp but i don't feel the car being held back as much which is what everyone has told would happen with this setup including my mechanic whom i've known for 12 years.
post Apr 7, 2012 - 4:38 PM
WhipCreamCelica
Joined Feb 1, '12
From The Colony, TX
I have a question, our current exhaust pipes go over the rear axle and bend like 3 times, is it a good idea to just have a straight pipe go under the axle and straight to the muffler
post Apr 7, 2012 - 5:41 PM
trdproven
Joined Aug 2, '05
From Guam
basic concept, is straighter pipe is better straight flow, some aftermarket exhaust don't follow OEM pipe paths and try to straighten it out as much as possible. a good example i saw was on a 240sx. early 90s
This post has been edited by trdproven: Apr 8, 2012 - 5:31 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 7, 2012 - 5:57 PM
WhipCreamCelica
Joined Feb 1, '12
From The Colony, TX
QUOTE (trdproven @ Apr 7, 2012 - 6:41 PM) *
Asom! Im doing it then, plus it'll have about 1 foot of less exhaust travel so itll probably be louder, thanx man
post Apr 8, 2012 - 5:31 PM
trdproven
Joined Aug 2, '05
From Guam
only thing is look at clearance and how low it hangs if its good with you.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 9, 2012 - 10:13 AM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
QUOTE (6gcpr @ Apr 6, 2012 - 6:28 PM) *
Im sorry I should have been more clear I was talking the diff between a 2in(recommended) exhaust and a 2.5in. Yes, the car will have more response when changing from stock because you in crease the air flow.
post Apr 9, 2012 - 12:18 PM
QUOTE (WhipCreamCelica @ Apr 7, 2012 - 5:38 PM) *
A lot of people are running under axle exhaust setups and have no issues. I've seen several 3s swapped cars rocking 3" under axle and don't ever have clearance issues. (lowered cars at that)
post Apr 9, 2012 - 12:30 PM
Culpable04
Joined Apr 17, '06
From New Jersey
I'm lowered on Tein coilovers, and I think I'm as low as I can go before I start to bottom out on the front or have clearance issues with my wheels tires ( 16x8 ET35 ) piping is ran under the rear subframe and I have no issues of exhaust hitting or anything like that. I do want to change it to go over, but that's because I hate how it looks, I want my exhaust to look more facotry. but no issues at all.
that's a 3in diameter piping.
post Apr 9, 2012 - 2:11 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (hatchy_gt-s @ Apr 9, 2012 - 11:13 AM) *
The key here is to not go too big. One of the most important functions of the exhaust is to suck air out of the cylinder. Too small and the exhaust creates backpressure which is bad but a small exhaust also creates high velocity airflow which is good. Too large an exhaust creates minimal backpressure which is good but also lowers the speed the exhaust travels through the pipes, which is bad.
Headers will give you the greatest performance boost because the pulses of exhaust gas will actually create a low pressure vacuum on the exhaust valves and thus help increase the flow of your cylinder head
The trick to the full exhaust system will be to find a pipe diameter that has the best balance of low backpressure vs high velocity flow. This is why minimizing the amount of bends and using mandrel bent tubing is so important because they will kill your exhaust's potential to help make power. Look into straightflow mufflers too, stock mufflers with all their baffles inside create some backpressure.
One last tidbit I'll leave you with is that your entire exhaust system is tuned to a specific frequency. The headers/manifold will have a specific harmonic(of exhaust pulses) they are tuned to based on primary pipe length and diameter. Also the muffler will be built with a specific rpm in mind which will be affected by how many cylinders are feeding it. You should do research on exhaust components before you buy them to determine what rpms they will be most effective at in regards to performance and noise reduction. (maybe highway speed is where you want maximum effectiveness at, or maybe close to redline. Its up to you.)
Lo-Fi Version Time is now: August 23rd, 2026 - 6:54 AM
