> Toyota Crash Bolts, Rear
post Apr 29, 2012 - 8:16 PM
drumbum
Joined Nov 29, '09
From Milwaukee
Are these crash bolts for the front and rear.....
I am using BC coilovers, but the rear camber isn't adjustable on our cars "98 GT"...... I did a little research and found a few part numbers
Toyota part number for 3 dot.... which gives the most adjustment...
90105-15011
Im not positive if these will work in the rear.... I couldn't find where toyota said the application was for front and rear to confirm it....
90105-15011
Found this older post
http://www.6gc.net/forums/index.php?showtopic=23750&hl=
trdproven stated they will work for the rear but just wanted to check to understand if i was reading the post right
heres a diagram for the front crash bolt specs...
http://home.earthlink.net/~celica73/camber.jpg
Weekend Warrior-----1998 Celica GT: White
Daily Driver----------1997 Celica GT: Blurple
post Apr 30, 2012 - 1:38 AM
trdproven
Joined Aug 2, '05
From Guam
now that I think of it when i ordered mine from EZ cam, all 4 looked exactly the same. when you think about it they are just used for the upper bolt, which means there is really no difference so I dont see why it should not work. both front and rear mounts on the strut are identical bolt sizes and style. that may explain why toyota does not state front or rear. im a bit interested aftermarket camber bolts usually only do 1.75+- and toyota ones can do 3 dot, IDK if that means 3 degrees though. plus those same camber bolts are used for many toyotas of differents models for either front or rear.
This post has been edited by trdproven: Apr 30, 2012 - 1:48 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: August 9th, 2026 - 11:20 AM
