> the *^%# Rattling noise!
post Dec 30, 2003 - 11:08 AM
Redline_Racer
Joined Oct 13, '03
From Dandridge, Tennessee
When I turn my music up my door hands and door panels rattle, do I have to take them off and tighten them up, or is there an easier way to fix this problem?
Thanks,
-Brandon
post Dec 30, 2003 - 7:31 PM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
secondskinaudio.com not easyer, not cheaper, but a lot better
post Dec 30, 2003 - 8:26 PM
Or get some RaamMat60 sound deadener, or Peel and Seal. Both of those are like Dynamat Extreme, but without the hefty price tag. wink.gif
post Jan 3, 2004 - 11:17 AM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
QUOTE (Coomer @ Dec 31, 2003 - 1:26 AM)
i have used peel and seal in the past but it didnt work to good.
post Jan 3, 2004 - 12:19 PM
Redline_Racer
Joined Oct 13, '03
Well I found my main rattle in my door, its my key hole haha, yeh. will that sound deadener work for that to?
Thanks for putting up with these dumb questions, haha,
-Brandon
post Jan 3, 2004 - 3:28 PM
QUOTE (BEEFSTEW800 @ Jan 3, 2004 - 8:17 AM)
Interesting...it works perfectly well for me. smile.gif What do you use now?
post Jan 5, 2004 - 10:06 PM
holson
Joined Aug 12, '03
From Boston, MA, USA
Yeah, something right behind my door panel rattles too. I can stop it by pushing the plastic trim piece against the door from the inside .
post Jan 5, 2004 - 11:35 PM
YellowTwo
Joined Jul 25, '03
From Santa Barbara, CA
I get this squeaking noise all the time, but I can only hear it when no music is on...sounds like it's coming from the door but I have no idea what it is.
post Jan 5, 2004 - 11:36 PM
The_Argon
Joined Feb 17, '03
From Adelaide, South Australia
I had a rattle in my car too, holding the pillar that the seat belt is on seems to stop it.
I took it in for a service about a month ago, now the rattle is gone redface.gif
post Jan 6, 2004 - 4:52 PM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
QUOTE (Redline_Racer @ Jan 3, 2004 - 5:19 PM)
          -Brandon
Brandon: hmmmmmm, i dont know what you could use on the keyhole. have you tried tightening the bolts that hold it? there should be 2 10mm bolts that hold it on, make sure they are tight. If that dosent work, you might try and deaden the hell out of the door so that you break up the sound waves before it gets to the keyhole. BTW they are not dumb questions because rattles are VERY ANNOYING.
Coomer: i have over 100 sq ft of second skins STFU 80 and Rattle Pad ordered, so ill see how it works. It is supposed to be better than Dynamat Xtreme.
-Stew
post Jan 17, 2004 - 12:59 AM
crazy95
Joined Dec 23, '03
I am currently starting to put some stuff I ordered off of Ebay its called B-Quiet in my car. Does anyone know how good this stuff actually works or did I just waste my money?
post Jan 17, 2004 - 11:05 AM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
Tells you everything you need to know about bargain sound deadeners
Lo-Fi Version Time is now: June 23rd, 2026 - 12:28 AM
