> Offsets and Hubcentric Spacers?
post May 11, 2012 - 10:33 AM
Syaoran
Joined Jan 4, '12
From US
Hey,
So I'm looking for wheel adapters to fit a set of BBS RX 16x7 +42 wheels that are 5x114.3.
Will a set of 25mm adapters fit fine in the car with no modifications needed, even lowered?
Also, do I really need the adapters to be centric to the wheel hub? Aren't acorn nuts supposed to center the wheel when tightened in a cross pattern?
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post May 11, 2012 - 11:16 AM
spy00005
Joined May 15, '09
From yonkers, NY
http://youtu.be/uagmGqeomng
http://youtu.be/1gU_XcLxcPw
i suggest hubcentric its better the acorn nuts don't guarantee its going to be centered perfectly.
This post has been edited by spy00005: May 11, 2012 - 11:18 AM
*Thing i want for my car(i wish i had money)*
-full gt4 front end conversion (DONE :) JUST NEEDS PAINT(next on to do list) -new seats all around
-riser blocks -fog lights -new radio and speakers all around
-full bodykit splitters and sideskirts to go with conversion (just needs fitting and painting)
-nice rims (Got TC rims and painted them white)
-light blue tint (next step will do this right after i get my paint job)
WTB Reasonably priced
Projectors just Lows
post May 11, 2012 - 11:23 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (spy00005 @ May 11, 2012 - 12:16 PM) *
Yes, I was watching those a while ago thank you. I am getting the spacers hubcentric. It's just that it is hard to find them wheel-centric as well for less than $200 for all of them lol.
post May 11, 2012 - 11:35 AM
spy00005
Joined May 15, '09
From yonkers, NY
yea that is true they cost a pretty penny. i know how you feel. maybe you get lucky like i did some one on here was selling his hubcentric 5x100 and i was able to pick em up at like half price with some use (i mean parts like these used won't matter.)
post May 11, 2012 - 3:13 PM
Syaoran
Joined Jan 4, '12
From US
My main question is how MUCH I need the spacers to be so I can clear the studs and clear the fenders as well? I'm not afraid of doing some negative camber in the front but I think it is unnecessary.
post May 11, 2012 - 3:47 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Take a look through these 2 threads, they should help you out.
http://www.6gc.net/forums/index.php?showto...l=wheel+fitment
My Celica!
post May 11, 2012 - 3:54 PM
Syaoran
Joined Jan 4, '12
From US
Already went through both of them. I still don't completely understand... The one that is the least vague is the flush fitment one but it still is vague.
I do understand what offset is and how it works. I just don't know how much clearance the front and rear fenders have.
This post has been edited by Syaoran: May 11, 2012 - 3:54 PM
post May 11, 2012 - 9:06 PM
ok simple.
since both rims are 7 yours and OEM
our cars come with a 38 offset rims..
you are using 42 offset, which means they will be sucked in.
for them to be at oem, you will need at least a 5mm spacer.
now your rims are 5 x 114.3
you have to have adapters to convert 5x100 to 5 x 114.3
the minimum for this is at least 20 mm.
regarding safety for a daily driver, i opted not to use these adapters, they need to be checked periodically for tightness, as if the adapter fails, you know what happens.
at 25 mm, you will probably require to roll the fenders.
i just found the perfect 35 offset rim, and no adapters, thats just me.
if you still want spacers, adapters, make sure they are hubcentric.
Lo-Fi Version Time is now: August 27th, 2026 - 1:21 AM
