> Stanley JDM tail lights, Wiring
post May 22, 2012 - 4:22 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
I know where there was a post about how the wiring was setup but this site search engine just sucks. If anyone can. Can they help me out. The problem I have is the reverse lights not working. I changed the bulbs and it still doesn't work. The fuse is not blown. The brake lights and turn signals works. It's just the reverse lights. Any ideas?
post May 22, 2012 - 5:43 PM
Box
Joined Feb 23, '12
From Warrior, AL
Have you known them to work at any time? If not it may be the backup switch.
2001 Miata LS 5-speed
post May 22, 2012 - 6:09 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Box @ May 22, 2012 - 6:43 PM) *
Actually when I purchased the car. Only the back right reverse light worked. The back left was blown. I replaced both and it worked for that night then I noticed both didn't work no more. I finally looked at the fuse and it wasn't blown. I checked the bulbs and it wasn't blown either? What is a back up switch anyways?
post May 22, 2012 - 6:49 PM
Box
Joined Feb 23, '12
From Warrior, AL
It's on the transmission, once you put the car in reverse it turns the backup lights on.
post May 22, 2012 - 7:23 PM
trdproven
Joined Aug 2, '05
From Guam
^ yea check the wiring on that
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post May 22, 2012 - 10:36 PM
ricochet1490
Joined May 3, '11
From Ohio
the switch sits directly on top of the transmission, I have it already take off my parts car and in my actual car. Check the wiring for sure..... it sits RIGHT on top
post May 23, 2012 - 12:50 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (ricochet1490 @ May 22, 2012 - 11:36 PM) *
So...........how would I get to it? Well I have to drop my transmission to check it?
post May 23, 2012 - 5:38 AM
taibones
Joined Feb 18, '08
From Kusel Deutschland
well i was asked today if my right side reverse light was a fog light, but any how you can always spice into the wiring form the side that works and run it to the other light if you need it working asap.
post May 23, 2012 - 12:53 PM
ricochet1490
Joined May 3, '11
From Ohio
QUOTE (ILoveMySilly97 @ May 23, 2012 - 1:50 AM) *
no it's on TOP the tranny lol. you'll have to remove your airbox hose at least.. maybe the box itself, but it literally is right there. and is very very inconspicuous.... I removed it for richee3 and he ended up not needing it, but it took me a min to find it to begin with.
post May 23, 2012 - 2:49 PM
Zaluss
Joined May 15, '12
From Renton, WA
http://www.casimages.com/img.php?i=1204300...86979789483.jpg
If its an automatic, the reverse lights are built into the neutral safety switch. I had similar issues as well. Check to see if the grounding points in your rear lamp assembly are properly seated (IE: check the screws to make sure they are tight, etc). Also look for grounding points along the wiring path from the engine to the rear.
post May 24, 2012 - 12:45 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (ricochet1490 @ May 23, 2012 - 12:53 PM) *
Ok. That's good news. Lol. So how does it look like anyways? Can you shoot me a pic of it?
QUOTE (Zaluss @ May 23, 2012 - 2:49 PM) *
Mine is actually a 5spd Manual Tranny. But I'll double check on the grounding wires.
post May 24, 2012 - 12:51 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
Your thinking of the tranny being under the due to it being a FWD the tranny is on the driver side of the engine. Just look around on it and see if you see any broken sensors.
post Jun 9, 2012 - 2:16 PM
ILoveMySilly97
Joined Mar 8, '12
Can anyone get a picture of the sensor? I couldn't find it?
Lo-Fi Version Time is now: July 29th, 2026 - 5:05 PM
