Closed TopicStart new topic
> CLOSE, please close
post May 24, 2012 - 9:30 PM
ricochet1490
Joined May 3, '11
From Ohio
AS the title says. need a 5s water pump with seals. Prefer new, will consider used depending on mileage.
Thanks
Edit:
Don't need the water pump, I'll just buy it... but could still use a timing belt and associated accessories.
Edit edit:
I'll just buy them both unles someone has one laying around they want to get rid of.
This post has been edited by ricochet1490: May 25, 2012 - 12:02 AM
post May 24, 2012 - 10:29 PM
vndroopy
Joined Oct 6, '09
From nyc
Just get them from rockauto.com . They pretty cheap and dont forget to use the discount code. If you need the code, just pm me.
post May 24, 2012 - 11:18 PM
ricochet1490
Joined May 3, '11
From Ohio
good call. Def not as expensive as I thought it would be. Was expecting 80$.... hmm
post May 24, 2012 - 11:58 PM
xrayjm
Joined May 12, '12
From Phoenix
Might want to consider the package with the timing belt and idlers, depending if its time. The oil pump set is cheap also.
post May 25, 2012 - 12:03 AM
ricochet1490
Joined May 3, '11
From Ohio
it's def time for most everything. 188k and I've put 40k on the car and never changed them. Lord only knows if they've ever been changed...
Lo-Fi Version Time is now: September 1st, 2026 - 3:23 PM
