> Misfire Issue during idle when cold, Misfire P0301
post May 29, 2012 - 10:54 AM
k-weaver
Joined Jun 5, '07
From Santa Maria
So a couple of weeks ago I noticed the car had a rough idle when cold. It would slowly smooth itself out as it warmed up. Once warm there were no issues at all. About 2 weeks ago the car through a CEL P0301 which is misfire in Cylinder 1. Here is what i've tried:
- Swapped spark plugs in cyl 1 and 2. Turned off cel. CEL came back with same code, still having same issues. Plugs have maybe 35k on them (NGK iridium)
- Replaced dizzy cap and rotor. While in there i found oil leaking into the cap and then down and out of the cap. Replaced o-ring seal on dizzy and also the seal for the cap. CEL came back, same code same issue.
I'll be heading to carquest today to pickup an inline spark tester. I think this test will pass though because the car runs fine once its warm. Right now i'm leaning towards an injector issue. I just put a full tank of gas and added about 5oz of lucas injector cleaner, i don't have high expectations of this working though.
Any suggestions you guys can offer will be appreciated. Just to re-iterate...Car runs perfectly fine once warm. No power loss, no hesitation. It actually runs alot better with the injector cleaner, new cap and new rotor (smoother and improved throttle response). Only issue is its rough when cold. You can hear and feel the misfire.
post May 29, 2012 - 11:27 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Use a compression tester, test it cold, hot and with a splash of oil inside the cylinder.
You can swap the injectors. Remove the 4 30mm nuts on the spark plug tubes then remove the valve cover. Use a wrench to remove the two bolts holding the fuel rail to the head.
post May 29, 2012 - 10:27 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Test the spark plug wires.
post May 30, 2012 - 10:17 AM
k-weaver
Joined Jun 5, '07
From Santa Maria
Got an update for you guys....when I got home last night I tested the spark plugs and they all appears to be firing the same. This morning I got in the car and started her up and there was a misfire like normal. I again tested the wire while the misfire was happening and this is what it looked like.
Flash flash flash...dead dead dead dead...flash flash flash flash...dead dead..flash..etc
So the problem appears to be spark related. Any thoughts on causes? Would seem weird for a plug wire to work when warm but not when cold. Plus the wires only have about 25-30k on them (ngk wires). Let me know what you guys think.
post May 31, 2012 - 4:01 AM
glenn
Joined May 21, '12
From Stockholm Sweden
QUOTE (Galcobar @ May 29, 2012 - 10:27 PM) *
I agree, this sounds exactly like the problems I had when my spark plug wires went bad.
For me it started when it was raining, and then it was with cold engine, and then all the time..
Black Toyota Celica GT-Four ST205 1996 (My love..)
Silver Toyota Celica GT ST202 1994 (Used to be my daily driver)
Parchment Silver SAAB 9-5 Aero sedan 2007
Black SAAB 9-5 Aero sportcombi 2005
Blue Pontiac Fiero 1984
Pearl white Tesla model 3 LR AWD 2020
Black Suzuki GSX1100e 1983 (My steam locomotive)
Red Honda NX650 Dominator 1992
post May 31, 2012 - 1:13 PM
Xander_X
Joined Apr 22, '12
From Central NY
99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo
2010 Acura RDX Turbo w/ Technology Package
68 Impala SS Convertable
post Jun 1, 2012 - 10:22 AM
k-weaver
Joined Jun 5, '07
From Santa Maria
QUOTE (Xander_X @ May 31, 2012 - 7:13 PM) *
What exactly can I "tune up" that hasn't already been done? This is what i've ruled out 100% so far:
1.)Spark plugs
2.)Spark plug wires (used my old set for testing, exact same issue)
3.)Dizzy cap/rotor
At first I was thinking injector issue but after visually seeing intermittent spark in Cyl 1 I think I can rule that out and safely assume an ignition issue.
post Jun 2, 2012 - 8:55 AM
Xander_X
Joined Apr 22, '12
From Central NY
Probably a bad Ignitor ... there's a chance it's the coil. How long did this start AFTER you replaced the dizzy cap and rotor? Might be a defective one.
99 Celica GT-S
post Jun 2, 2012 - 10:42 AM
k-weaver
Joined Jun 5, '07
From Santa Maria
QUOTE (Xander_X @ Jun 2, 2012 - 1:55 PM) *
This was an issue prior to replacing. I replaced originally to try and fix the problem im currently having. Im thinking its either the igniter or the dizzy itself. Both of which are not cheap parts >.< any way to test either without replacing?
post Jun 3, 2012 - 12:38 AM
hokuten3
Joined May 30, '10
From PA
could be grounding. sounds impossible, but that's what happened to me.
...5sFREAK...
Lo-Fi Version Time is now: July 31st, 2026 - 10:42 AM
