> amp wont stop buzzing, cant figure it out
post Jun 17, 2012 - 12:50 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ok so ive got a question.
Can bad aux wire cause that super annoying whining sound.
I went through my system today an redone my ground an i know its big enough for my amp
The ground an power are good for 650 an my amps only 250.
so im figuring its gotta eather be the aux wires or the actual radio ground
As long as i have the amp set for bass only the whine isnt there but since i have 4 subs it would be nice to turn on the vocals too
94 st hatch my daily driver
n
post Jun 19, 2012 - 2:43 PM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
Are your rca inputs run alongside your power wire all the way to the back? They need to be on opposite sides of the car or you will get a whine. And yes I would try temporarily running new wires from the deck to the amp as they will definitely cause a whine
ST205 Crew represent
Challenge Accepted
post Jun 20, 2012 - 10:05 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
You can purchase shielded wire if all else fails. Its got a foil sheathing that you ground to the vehicle chassis. Some of the EFI sensors have them
post Jun 20, 2012 - 11:26 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
My amps under my drivers seat.
The power wire is ran from the battery down the drivers side to the amp under the seat
an the rcas are run from the center console to the amp
n
post Jun 20, 2012 - 11:49 AM
richee3
Joined Jun 29, '08
From Denver
If one of the aux wires is loosely connected, it can make the same buzzing. It's something that's easy to check and easy to fix.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 20, 2012 - 12:05 PM
mkernz22
Joined May 10, '10
From MA
The amp I use to have in my car hummed when I first put it in because I ran a straight 12v power lead to it from the battery (with a switch). I didn't leave it like that cause it wasn't that way in my other car so I actually used the antenna turn on wire and it stopped humming
post Jun 20, 2012 - 1:29 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ok well ill try a pick up a new set of rcas this weekend a if that doesnt work ill redo my remote wire an see what hapoens
n
post Jun 20, 2012 - 2:57 PM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (schmooot @ Jun 19, 2012 - 3:43 PM) *
Technically not true, unless he is feeding other higher spectrum speakers which will pick up such whine. Sub amps filter that out, unless he has the filter way way up.
Mine are run together with no whine, and are not shielded.
Most likely you have a bad ground, or your alt is causing the whine.
This post has been edited by rave2n: Jun 20, 2012 - 2:57 PM
post Jun 20, 2012 - 3:41 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Could upgrading the grounds under the hood help
My grouund now is where the seat rail bolts to the floor
And yes i sanded all the paint off
n
post Jun 20, 2012 - 3:49 PM
rave2n
Joined May 29, '09
QUOTE (kurt95gt @ Jun 20, 2012 - 4:41 PM) *
Check the ground on the head unit, or make a new one all together for it.
Also check to make sure connections to alt are secure.
post Jun 20, 2012 - 4:47 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Ok
Ill look at all of that this weekend too
n
post Jun 20, 2012 - 6:39 PM
trdproven
Joined Aug 2, '05
From Guam
RCA wires are next to ground wires or you have a bad ground.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jun 21, 2012 - 10:07 AM
narly_charley
Joined Sep 1, '09
From Marengo, IL
You don't want to create a "ground loop". Ground all the sound stuff at one point on the body, that is usually the problem.
2000 GT-S 6 SPD... SOLD!
post Jun 21, 2012 - 10:23 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
So i should ground the amp an radio in the same place
n
Lo-Fi Version Time is now: July 30th, 2026 - 2:40 PM
