Jun 24, 2012 - 2:29 AM
Enthusiast Joined Jun 24, '12 From Texas Currently Offline Reputation: 0 (0%) |
Spent 8 hours in the brutal TX heat trying to figure out why a 10 amp fuse blows when I turn my AC on. When I replace the fuse it blows immediately. A buddy and I looked for bare wires, and racked our brains all day. Even replaced the compressor relay and that didn't work either.
Any help or insight will be extremely appreciated. when we pulled out the ac relay the heater would blow and the fuse wouldn't pop if that helps any. This post has been edited by Samuel: Jun 24, 2012 - 3:06 AM |
Jun 25, 2012 - 9:33 AM
Enthusiast ![]() ![]() Joined Mar 1, '12 From iowa Currently Offline Reputation: 0 (0%) |
Sounds like you have a bare wire somewhere. Try checking from the ac relay as starting point.
Jun 26, 2012 - 6:16 PM
Enthusiast ![]() Joined Dec 30, '11 From Atlanta via Mobile Currently Offline Reputation: 0 (0%) |
Sounds like you have a bare wire somewhere. Try checking from the ac relay as starting point. Disconnect the compressor as a start. Turn it on to see if it blows. If it doesn't you can connect a test light inline and see it if lights. Its got a short if it does. Don't have a test light? Buy one. -------------------- |
| Lo-Fi Version | Time is now: August 29th, 2026 - 2:41 PM |
