> Need loads of negative camber...
post Jul 11, 2012 - 9:47 AM
ricochet1490
Joined May 3, '11
From Ohio
Ok, so We're starting in to building our dirt track car. Any of you who've ever been to a race know the front right always has a load of negative camber in it.
So, I know I have some negative camber adjustment in the strut mount at the hub, But I think I'd like to get a little more than that.
I saw some top mounting plates by cusco and some other manufacturers, but I'm sure how much negative camber would be allowed with those.
I"m looking for about 3-5 degrees negative. Any sugggestions? Not looking to go too high dollar and the likelihood of damage is very high lol
post Jul 11, 2012 - 6:02 PM
trdproven
Joined Aug 2, '05
From Guam
5 degrees seems a bit too much, i don't even know if it will clear your suspension if anything depending on your wheel/tire set up. I'm really confident you won't find anything like camber bolts to camber your car between 3 and 5. maybe at the most 2.75 IDK? Maybe sounds even crazy to me, depending on your wheel tire setup try adjusting your camber plates plus bolts, <<< yea IDK thats just for the fronts, sounds crazy never heard anyone try or do that. but then again, if your car is dropped pretty good it can give you avg 2-4 degrees negative NATURAL camber already plus the camber bolts adjustments, might make you reach your goal.
This post has been edited by trdproven: Jul 11, 2012 - 6:12 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 11, 2012 - 6:12 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
i was thinking the same. plates and bolts. doubt that will do it though
エキサイティングカーレーシングチーム!
post Jul 11, 2012 - 8:07 PM
ricochet1490
Joined May 3, '11
From Ohio
yeah it's going on the dirt track... look at this for a better idea
http://www.allleftturns.com/why-sprint-cup-needs-cup-race
The body roll on the right side is why I need the neg camber... so that tire is "flat" through the corner if that makes sense
post Jul 12, 2012 - 10:02 PM
qatar11
From Lake Orion, MI
I have Ingalls (http://www.ingallseng.com/) camber bolts in the upper and lower position... they claim you can get 2 degrees each.... we run 2.5 degrees for raod racing... so you should be able to get at least 3....
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post Jul 13, 2012 - 1:11 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Custom Camber arms?
My Celica!
post Jul 14, 2012 - 7:09 AM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (trdproven @ Jul 12, 2012 - 9:02 AM) *
^ This should be a solution, for the rears, if dropped low enough, cambers pretty bad already plus bolts will make the rears no problem to adjust for negative camber. and then for the fronts are just what I posted earlier.
This post has been edited by trdproven: Jul 14, 2012 - 7:09 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: August 4th, 2026 - 9:48 AM
