Nov 18, 2012 - 10:14 PM
Im tired of jumstarting my car every 8 th day.. If not used. My baterry was new, and keeps loosing juice while not in juice, I know it may be something normal, but too quick is too soon.
Its not the radio, and its not my amp, cuz i dont have one? any takers? -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Nov 18, 2012 - 10:23 PM
Enthusiast ![]() ![]() Joined Mar 4, '10 From Bronx NY Currently Offline Reputation: 3 (100%) |
Im tired of jumstarting my car every 8 th day.. If not used. My baterry was new, and keeps loosing juice while not in juice, I know it may be something normal, but too quick is too soon. Its not the radio, and its not my amp, cuz i dont have one? any takers? I know this is not the answer but dam just wanted to add that I've been having that problem since I got my car -------------------- Always fast and going for the look......
Nov 19, 2012 - 12:20 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
is the alternator charging the battery? if its not a short, a ground, battery connections, or a battery it might be a positive battery cable problem. had a similar problem with my car (battery relocation in the trunk). i switched to zero gauge wire and havent had issues since.
Nov 19, 2012 - 1:55 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) |
Im tired of jumstarting my car every 8 th day.. If not used. My baterry was new, and keeps loosing juice while not in juice, I know it may be something normal, but too quick is too soon. Its not the radio, and its not my amp, cuz i dont have one? any takers? Its called 'parasitic battery drain' and here is how to test for it- -Remove the negative battery cable -Make sure the car is completely off (*A door ajar powering the interior lights may blow your multimeter's fuse!*) -Set your multimeter to measure milliamps in DC -Connect the multimeter's negative lead to the battery's negative post -Connect the multimeter's positive lead to the negative battery cable or a common ground(like the engine) -The measurement should be roughly* .005 - .02 amps on most cars -Pull one fuse at a time and measure the current drop on the multimeter. The fuse that drops the current the most is the parasitic drain. I would also suggest pulling the relays one by one. Dont forget to never open the doors or power anything up on the car with the multimeter completing the car's circuit, as you can easily damage the multimeter if you are careless. This post has been edited by Special_Edy: Nov 19, 2012 - 1:59 AM |
Nov 19, 2012 - 9:04 AM
![]() Enthusiast ![]() ![]() ![]() Joined Apr 22, '12 From Central NY Currently Offline Reputation: 5 (100%) |
^This. Got to it before I did. Or if you get one with a clamp you can just clamp it around your ground cable.
-------------------- 99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo 2010 Acura RDX Turbo w/ Technology Package 68 Impala SS Convertable |
Nov 19, 2012 - 9:37 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
Nov 19, 2012 - 9:57 AM
I talked my dad into buying me one. He own's an electrical company and I told him I could use it for work
Nov 19, 2012 - 11:53 AM
Or you could use a pair of vice-grips the hold the electrode to the battery terminal. Heck a clothes pin may even hold it.
This post has been edited by Special_Edy: Nov 19, 2012 - 11:54 AM |
Nov 19, 2012 - 3:45 PM
ill try the test, but damn it appears to be a long one. yes ive had that drain for 2 years, and its not a radio, unless the battery of the radio is the size of a horse. thanks for the reply, it gives me an idea.....
Nov 21, 2012 - 2:26 AM
![]() Enthusiast Joined Oct 24, '10 From Chicago Currently Offline Reputation: 0 (0%) |
This post has been edited by clownpRon: Nov 21, 2012 - 2:27 AM |
Nov 21, 2012 - 7:25 AM
Have you checked at night to make sure your lights are cutting off? Figured check that before you go pulling each fuse!
Nov 22, 2012 - 12:12 AM
Have you actually peeked at your car at night to see if their is a Gremlin eating out of it?
Nov 22, 2012 - 2:09 AM
not yet, but im considering one of these for giggles...
http://www.tirerack.com/accessories/catego...egory=Batteries -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
| Lo-Fi Version | Time is now: August 26th, 2026 - 7:39 AM |
