> CV Axle, fit auto or manual?
post Nov 19, 2012 - 1:03 PM
Jokester
Joined Dec 22, '11
From California
So I need to replace my front right side axle cause everything I turn right, it make a loud clicking noise. I'm guessing the CV boot is ripped or something? Anyways getting a new axle.
Now my question would an axle for a GT fit both automatic and manual? Or is there different type for each one?
As far as I know, there is different axle for the ST & GT, but not sure about auto & manual. Any help would be great. Thinking of getting the axle from ebay, thats why.
post Nov 19, 2012 - 1:11 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (Jokester @ Nov 19, 2012 - 2:03 PM) *
I am in Cali also I just went to oreilys auto and picked up a passenger cv for 69.00.
They were the best deal and you can bring it back if you were to get the wrong one somehow.
post Nov 19, 2012 - 3:05 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Yes there should be 8 different sets of axles for US 6gcs.
7afe manual without ABS
7afe manual with ABS
7afe automatic without ABS
7afe automatic with ABS
5sfe manual without ABS
5sfe manual with ABS
5sfe automatic without ABS
5sfe automatic with ABS
To my knowledge, the 7afe and 5sfe axles are not interchangable. I also believe the automatic and manual transmission axles are different due to either length or spline count. Finally the ABS equipped axles(they have a ring with notches near the threaded end) may be fully compatable with non-ABS cars. I have ABS 5sfe manual axles in my non-ABS 5sfe manual. Of course if you put a non-ABS axle into an ABS equipped vehicle the ABS light will come on and the system wont function correctly.
I got my remanufactured cv-axles at autozone for $60 a piece and it took them two days to order them. One thing you may want to count on is that the other axle will probably start to fail once you replace the side that's acting up now. They wear out pretty evenly just like tires or brakes but this is no reason to replace both(when only 1 is bad) unless its cheaper or more convienient for you based upon your circumstances.
Hope that helps answer your question
This post has been edited by Special_Edy: Nov 19, 2012 - 3:06 PM
post Nov 19, 2012 - 6:42 PM
Manual and auto have specific axles, but you can use an ABS axle on a non-ABS car. Just remove the ABS ring assembly, it's three pieces that slide off with the aid of a mallet and flathead.
This post has been edited by SwissFerdi: Nov 19, 2012 - 6:42 PM
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Nov 19, 2012 - 7:25 PM
Jokester
Joined Dec 22, '11
From California
Thank you for your help guys! Here is what I've got from Pep Boys and O'Riely. So yes, 5SFE and 7AFE have different axle.
As far as the 5s goes, for the right side, it uses the same axle for both automatic and manual. But for the left side, there a is a specific one for the manual and and another for the auto. Don't ask me why, thats how it is I guess.
So another question. If every time I turn right and hear loud clicking sound from underneath front of the car, that is the RIGHT axle, correct? Because I check the right axle and none of the boots are torn/damage. However, when I check the left axle, it's boot is torn. Any advice please?
P.S, the ABS info is quite helpful, thanks!
This post has been edited by Jokester: Nov 19, 2012 - 7:26 PM
Lo-Fi Version Time is now: September 4th, 2026 - 8:05 PM
