> Stuck clutch?
post Dec 13, 2012 - 10:29 PM
Liam_c
Joined Nov 29, '12
From New Zealand
Hey guys
I recently bought my Celica and on the test drive, i changed gear, and when the pedal released, it seemed to be stuck halfway. I managed to get the car to the side of the road, and the owner said it was just the mat stuck by the pedal. I didn't get to see what he did, but i assumed he had moved the mat, and we were away again. Anyway, i liked the car, and ended up buying it.
1 month (ish?) on today, i was driving around a car park, when the clutch did the exact same thing! It wouldn't return, and i could not move that car at all kindasad.gif
After a bit of pumping of the clutch i managed to get it to return, and since have done 100kms with no problem (was definitely not the floor mat mad.gif )
Took it to my local mechanic, and he didn't notice any problems. He said that my fluids are good and that the spring / pedal assembly for my clutch appear okay. He did mention something about the master cylinder, but he couldn't tell as the clutch was operating fine when he looked at it.
Any ideas? Any one had something similar happen before?
Cheers, Liam
This post has been edited by Liam_c: Dec 17, 2012 - 6:59 AM
post Dec 14, 2012 - 11:05 AM
the master or slave cylinder is leaking internally. either replace the slave or rebuild the master
post Dec 14, 2012 - 12:20 PM
1994whitecelicag...
Joined Nov 13, '12
From Sacramento
I had the same problem! So far I've changed both the master and slave cylinder. After asking around, alot of mechanics said it was probably the release bearing. So I'm working on installing a brand new clutch kit in my 94 celica.
post Dec 14, 2012 - 2:27 PM
the throwout bearing will have nothing to do with those effects. those mechanics are idiots!
post Dec 14, 2012 - 3:07 PM
Liam_c
Joined Nov 29, '12
From New Zealand
The mechanic did say that he thought the slave had been replaced at some point...
Think i might rebuild the master and see how i go (if it does it again)
post Dec 16, 2012 - 8:28 PM
trdproven
Joined Aug 2, '05
From Guam
slave and master has been covered many times, I'm sure it will help you diagnose.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Dec 16, 2012 - 10:55 PM
Liam_c
Joined Nov 29, '12
From New Zealand
The clutch did it again! And again it was in a car park ...
I've got the local mechanic ordering in a master cylinder.
It seems to be doing it (usually) after i've put it into second gear
Lo-Fi Version Time is now: August 4th, 2026 - 10:10 AM
