Jan 4, 2013 - 10:40 PM
Enthusiast ![]() ![]() ![]() Joined Nov 25, '08 From dillsburg pennsylvania united states Currently Offline Reputation: 12 (100%) |
those that have st and bt 4age motos this is a list of some part number of specific items. if i find more ill be sure to share!
Silvertop TPS sensor: 89452-12080 or 89452-22080 same p/n as 2JZGTE, 3RZFE, 2RZFE, 5VZFE Blacktop TPS sensor: 89452-12090 Silvertop IACV (idle control valve): 22270-16030 Blacktop IACV: 22270-16070 Blacktop Electric Fan Water Temp Sensor (the white one):89428-12160 Silvertop Electric Fan Water Temp Sensor : *unknown* Blacktop Oil Pressure Sensor: 83520-35030 Silvertop Oil Pressure Sensor: 83520-35030 Blacktop Knock Sensor: 89615-22050 Silvertop Knock Sensor: *unknown* Blacktop O2 Sensor: 89465-19685 Silvertop O2 Sensor: 89465-19495 or 89465-12290 Blacktop Water Temp Sensor for Gauge Cluster :83420-20040 Silvertop Water Temp Sensor : *unknown* Blacktop MAP sensor: 89420-12070 Silvertop Air Flow Meter: 22250-16110 Blacktop Igniter: 89621-12050? Silvertop Igniter: 89621-12050? same as SW20 MR2? Blacktop Ignition Coil: 90919-02197 Silvertop Ignition Coil: 90919-02197 same as 3SFE, 2JZGE? Blacktop VVT Solenoid: 15330-16020 Silvertop VVT Solenoid: 15330-16010 or 15330-16020 *****MAINTANENCE******* Blacktop "Gasket Overhaul kit": 04111-16210 Silvertop "Gasket Overhaul kit:: 04111-16330 Blacktop Timing Belt: 13568-19185 Silvertop Timing Belt: 13568-19035 Blacktop Alternator Belt: 99365-80840 Silvertop Alternator Belt: *unknown* Blacktop Timing Belt Pulley: 13505-16030 Tensioner for Pulley: 13540-16010 Silvertop Timing Belt Pulley: 13505-16021 or 13505-16030 Tensioner for Pulley: 13540-16010 Blacktop Thermostat: 90916-03075 Silvertop Thermostat: 90916-03060 Blacktop Distributor Cap: 19101-16010 Rotor: 19102-74040 Silvertop Distributor Cap: 19101-16010? Plugwire Set: 90919-21520 Oil Filler Cap: 12180-46010 same as 2JZ Valve Clearance Adjusting Shim: 13751-16020 PCV valve: 12204-11050 Spark Plug Hole Gasket: 11193-16010 *****ENGINE MECHANICAL****** Blacktop Distributor Assembly: 19100-16270? Silvertop Distributor Assembly: 19100-16270? Blacktop Oil Pump: 15100-19045 Silvertop Oil Pump: 15100-19036 Blacktop Water Pump: 16100-19285? Silvertop Water Pump: 16100-19245? Blacktop Valve Cover: 11201-16030 Silvertop Valve Cover: 11201-16020 or 11201-16030 Blacktop Oil Pan: 12101-16100 Silvertop Oil Pan: 12101-16100 same as 5AFE and 4AFE? Blacktop Oil Pump Pickup Tube: 15104-15090 same as 5AFE? Silvertop Oil Pump Pickup Tube: 15104-15090 -------------------- ![]() those with golf balls golf those with real balls race |
| Lo-Fi Version | Time is now: August 28th, 2026 - 1:46 AM |
