Jan 19, 2004 - 10:16 PM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 30, '02 From North Carolina Currently Offline Reputation: 0 (0%) |
Well I got a boost controller and I put it on and now its blowing the pipes apart like the BOV aint woking, any suggestions, im only boosting 5 psi!
-------------------- 99 Toyota Tacoma
Jan 19, 2004 - 11:07 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
Is your BOV set for 5psi also? If its to tight and doesn't want to release till say 10psi then you will have boost surge. Try to loosen the bov a bit.
-Bryan- -------------------- Member of Team 5sfTe
Jan 20, 2004 - 10:41 AM
Well I have no weights in the BOV at all so it should be going off right?
Jan 20, 2004 - 1:35 PM
There should be a bolt either on top or the side that you use to tighten or loosen the valve. Tighter for more boost and looser for less.
Jan 20, 2004 - 1:57 PM
Enthusiast ![]() ![]() ![]() Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) |
adjust it here.
Jan 20, 2004 - 2:40 PM
Enthusiast ![]() Joined Sep 30, '02 From san diego Currently Offline Reputation: 0 (0%) |
I had the same problem when I turbo'd mine. Do you have a lip welded around the ends of you pipes?
| Lo-Fi Version | Time is now: May 18th, 2026 - 2:01 AM |
