Mar 25, 2013 - 4:59 PM
I have a st204 standard transmission. Planning on changing my fluid to Pennzoil synchromesh to see if it'll help out on the 3rd gear grind. Now I know that they're 24mm nuts and I have the wrench and socket for it. The only problem I have is trying to break them loose. Them nuts are just so skinny and flat and big that it's so easy to strip them. Also they're in a hard angle too. Anyone have any ideas or tricks?
Mar 25, 2013 - 7:48 PM
Enthusiast ![]() ![]() ![]() Joined Jan 26, '09 From Los Angeles Currently Offline Reputation: 1 (100%) |
I used a short 24mm 3/8drive socket on a 8in ratchet with a 2ft. breaker bar. I slide half of my jack handle over the ratchet handle as my ghetto breaker. Though, that combination is worth its weight in gold. I don't know how many stubborn bolts I've gotten off with that thing haha
Also, I undid both of them from underneath the car..just go for it! -------------------- |
Mar 25, 2013 - 9:56 PM
Funny, I just had to do this tonight. I have to use an end wrench for the drain plug, but my 3/8 ratchet does the job for the fill plug. I've never had any problems breaking mine loose though. Try Malek's method, a cheater bar works wonders.
Mar 25, 2013 - 11:09 PM
Short? Short meaning the regular size right? Or is there short ones, reg ones, and deep ones? Lol. I did use a cheater bar btw. Did it twice and slipped the filler nut twice. Didn't want to risk stripping it anymore so I just stopped and came here. I really wished it was. 17mm like other cars. Would've made it easier. Or made the nut bigger since its 24mm.
Mar 25, 2013 - 11:20 PM
hmm..you may want to try a 12 point socket if you keep slipping off like that. I usually hold the ratchet head on the bolt to make sure I'm putting even pressure around it..It really shouldn't be that hard to turn!
I remember getting one of those off with an adjustable wrench -------------------- |
Mar 25, 2013 - 11:29 PM
Lol. I was using a 12 point socket too btw. With my left hand on it to put pressure on it also. I think ima have to try it again but this time with my older bro holding it in place while I break it loose.
Mar 26, 2013 - 12:57 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) |
When you manage to take it out, get a M18x1.5 bolt with a better head for easier removal next time. You should be able to find them at Pepboys, Napa, Advance Auto Parts and Autozone in the bolts/washers/fittings/pcv valves/etc section.
The way I did it was as somebody mentioned above. I held the ratchet against the bolt with one hand from the top of the car for the fill plug. I used a long 24mm socket though. This post has been edited by Syaoran: Mar 26, 2013 - 12:58 AM -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Mar 26, 2013 - 3:18 AM
That m18x1.5 is for bother the fill and drain nuts right?
Mar 26, 2013 - 4:51 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '12 From Brisbane, Australia Currently Offline Reputation: 6 (100%) |
Oohh, I have the 3rd gear grinds too and was ignoring it because I didn't want to have to drop out the tranny... Let us know if this helps! -------------------- ![]() SOLD :( 1997 ST204 Celica ZR -----> See it here on 6GC! 2013 October Celica of the Month XD Now: '00 NB8B Mazda MX5 -----> See it here in off topic! |
Mar 26, 2013 - 5:07 PM
Oohh, I have the 3rd gear grinds too and was ignoring it because I didn't want to have to drop out the tranny... Let us know if this helps! A lot of 6gc members has done this and it seems to be the best cure or aid for our common 3rd gear grind. -------------------- |
Mar 26, 2013 - 5:26 PM
Oohh, I have the 3rd gear grinds too and was ignoring it because I didn't want to have to drop out the tranny... Let us know if this helps! A lot of 6gc members has done this and it seems to be the best cure or aid for our common 3rd gear grind. That's great! I don't know why I haven't seen any posts about it before... I guess I always just skip the boring maintenance and look at the engine swaps and project threads I now have another thing to add to the list for my big service coming up -------------------- ![]() SOLD :( 1997 ST204 Celica ZR -----> See it here on 6GC! 2013 October Celica of the Month XD Now: '00 NB8B Mazda MX5 -----> See it here in off topic! |
Mar 26, 2013 - 6:38 PM
That m18x1.5 is for bother the fill and drain nuts right? Yes. When you take them out you'll see it's the exact same bolt. -------------------- 1993 Celica GT Coupe - sold
Mar 27, 2013 - 12:37 PM
That m18x1.5 is for bother the fill and drain nuts right? Yes. When you take them out you'll see it's the exact same bolt. Ok. Thanks for this info. -------------------- |
Mar 27, 2013 - 2:33 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
Soak them in PB blaster for a day. That'll loosen them up nicely.
Correct socket, and dead blow mallet. Comes right out. I've tried before with other agents, with no success. |
Mar 31, 2013 - 9:16 AM
and stay away from the 12pt socket if you can, it will just round the head off faster.
i bought a 24mm wrench down @ the local autozone just for this purpose, use it from under the car (with the underplastic removed, obviously) with a hammer or mallet works for me every time. -------------------- Former Team 5SFTE pro member ;)
Mar 31, 2013 - 4:21 PM
and stay away from the 12pt socket if you can, it will just round the head off faster. i bought a 24mm wrench down @ the local autozone just for this purpose, use it from under the car (with the underplastic removed, obviously) with a hammer or mallet works for me every time. You can get to it with a wrench. At least not the filler nut from the bottom. -------------------- |
Apr 5, 2013 - 5:33 PM
I officially given up. My brother and I was battling this filler nut for an hour and half. Im just going to take it into the shop before I strip it even more.
Apr 5, 2013 - 10:20 PM
Use a 1/2" drive and a 24mm socket. Then jack the car up enough to get the drive on the filler one. It's actually easier to use a breaker bar for it. Or use a 1/2" drive and hit it with a decent small sledge hammer. I got it broken free on my friends car. It's really not that hard or difficult as it seems, just have to use the right technique
Apr 5, 2013 - 10:46 PM
Use a 1/2" drive and a 24mm socket. Then jack the car up enough to get the drive on the filler one. It's actually easier to use a breaker bar for it. Or use a 1/2" drive and hit it with a decent small sledge hammer. I got it broken free on my friends car. It's really not that hard or difficult as it seems, just have to use the right technique I used a cheater bar and hammer. Everytime I hit it or pull it. It just slips right off. The angle of the nut is just too damn ugly. It's like in a 45 degree angle or something. Only if I had a impact gun. Would've been easier. Plus the heads about stripped enough to where the socket slips easily with a little nudge. -------------------- |
Apr 8, 2013 - 12:50 PM
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
I got pissed at mine and gave it a quick blip with my impact gun. Just enough to break the tension, then I used a ratchet to get it the rest of the way. FYI I would not recommend doing this with a cheap non-variable speed gun. Mine is variable speed and I barely blipped the bolt.
| Lo-Fi Version | Time is now: August 27th, 2026 - 6:30 AM |
