Mar 28, 2013 - 3:54 PM
Enthusiast Joined Feb 26, '13 From Hull, UK Currently Offline Reputation: 0 (0%) |
hey just bought my first celica and am looking for some help to get it running how i would like. the front cv joint clicks while turning so i have got myself a replacement drive shaft and am going to change it out over the weekend. the only issue is that its passenger side and all the how2s i can find seem to deal with drivers side onle. its a 1997 2.0 gt uk model with abs. any help or advice would be greatly appreciated.
cheers Vinny |
Mar 28, 2013 - 4:03 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
Just make sure the ABS ring is present.
-------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Mar 28, 2013 - 4:08 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
Passenger side is cake. Just remove the axle bolt from the hub. Move it out of the way, then remove the 2 bolts that are in the middle of the shaft attaching to the bracket.
Slides right out of the trans. Edit: make sure you drain the trans first! This post has been edited by rave2n: Mar 28, 2013 - 4:09 PM |
Mar 28, 2013 - 4:16 PM
cheers. abs ring is there and ready to go in. its just that ive seen a couple of how2s and they say to strip everything down completely.
Mar 28, 2013 - 5:33 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Passenger side is cake. Just remove the axle bolt from the hub. Move it out of the way, then remove the 2 bolts that are in the middle of the shaft attaching to the bracket. Slides right out of the trans. Edit: make sure you drain the trans first! His is RH drive probably since he's from the UK. -------------------- ![]() ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Mar 28, 2013 - 6:06 PM
Passenger side is cake. Just remove the axle bolt from the hub. Move it out of the way, then remove the 2 bolts that are in the middle of the shaft attaching to the bracket. Slides right out of the trans. Edit: make sure you drain the trans first! His is RH drive probably since he's from the UK. Hah good point! - Pry away, or slide hammer with fork. |
Mar 28, 2013 - 7:32 PM
im guessing that means there is a difference in how they come out of the transmission, depending on what side of the car its on?
Mar 29, 2013 - 6:34 AM
im guessing that means there is a difference in how they come out of the transmission, depending on what side of the car its on? Yessir. The short shaft has a c-clip on the end, and requires prying out, or using a slide hammer with a fork on it. The longer shaft is simply held in place with a bracket in the middle, and just slides in and out the trannie without a clip. Either way, both sides you are going to disconnect them from the wheel assembly via the axle nut. I remove the strut bolts so I have more room to move the hub around. Once you remove the bottom end from the wheel assemblies you just go at depending on which you are working on. The one with the clip can occasionally be a pain, if it takes you more then 30 minutes prying to get it out, I would go find a slide hammer. This post has been edited by rave2n: Mar 29, 2013 - 6:35 AM |
Mar 29, 2013 - 9:04 AM
Enthusiast ![]() ![]() ![]() Joined Jan 26, '09 From Los Angeles Currently Offline Reputation: 1 (100%) |
im guessing that means there is a difference in how they come out of the transmission, depending on what side of the car its on? Yessir. The short shaft has a c-clip on the end, and requires prying out, or using a slide hammer with a fork on it. The longer shaft is simply held in place with a bracket in the middle, and just slides in and out the trannie without a clip. Either way, both sides you are going to disconnect them from the wheel assembly via the axle nut. I remove the strut bolts so I have more room to move the hub around. Once you remove the bottom end from the wheel assemblies you just go at depending on which you are working on. The one with the clip can occasionally be a pain, if it takes you more then 30 minutes prying to get it out, I would go find a slide hammer. [size="4"][/size] Don't even waste your time trying to pry it out! If you can go rent a slide hammer (maybe not in the UK..?) then do that and take 5 seconds to pull the axle out! I wasted idk how much time fking with it until I drove myself to Advanced Auto and rented a slide hammer with a hook attachment. First slide of the hammer and it popped out. I was a little upset at myself for wasting so much time.. -------------------- |
Mar 29, 2013 - 11:22 PM
Don't even waste your time trying to pry it out! If you can go rent a slide hammer (maybe not in the UK..?) then do that and take 5 seconds to pull the axle out! I wasted idk how much time fking with it until I drove myself to Advanced Auto and rented a slide hammer with a hook attachment. First slide of the hammer and it popped out. I was a little upset at myself for wasting so much time.. Feel ya. I've pulled that axle 5 times now, the first 2 times easy...next 3. I was screaming so loud the area thought I was crazy. Rent the slide hammer, 15 seconds its out. Truly though, I've noticed if the axle doesn't have any play when into the trannie, it comes out easy with a few taps and a pry bar. Possibly a bearing going bad, or just old age..no idea, but it appears on the abused transmission it takes alot of work to get that beast out. |
Mar 30, 2013 - 2:28 AM
Just get underneath and using something flat lean it against the cv axle going into the transmission and tap on it outwards then rotate axle, tap again, rotate, tap again until it comes out and then pull it off. Super easy and doesn't even require a slide hammer.
Apr 4, 2013 - 2:24 AM
done it cheers guys. was the short side axle. left the entire hub assembly together it just moved out of the way. gave the shaft a good old tug and the inside joint collapsed. blessing in disguise realy as i had loads of room to stick a prybar in each side and it popped out no worries.
| Lo-Fi Version | Time is now: August 29th, 2026 - 5:21 PM |
