> WTB 5S-FE aftermarket parts, moar powaaaa
post Apr 14, 2013 - 8:57 PM
playboymma
Joined Jan 7, '11
From Mena, AR
looking for some aftermarket cams, pistons, and valves/springs for a 5sfe
Reason for edit: please remember to add 'WTB' in the topic title and have a clearer title
I went full retard once, too. Its OK.
post Apr 16, 2013 - 4:14 PM
94celicadude
Joined Mar 28, '04
From St.Louis
I have a set of Webcams 294 Regrind cams in my 5S, just took the motor out last weekend.
I'd be willing to take them out and ship them for the right price!
I also have a few other things you may be interested in if you're looking to get more power from your 5S.
Mine put down 132 WHP and 150 WTQ with all the mods I had done.
Message me if you're interested in anything!
Matt
1994 GT Hatchback
1994 ST Coupe
1988 Corolla Wagon All-Trac
1999 Corvette
2008 Cobalt SS Turbo
post Apr 16, 2013 - 4:58 PM
valves and springs are not going to give you an increase in power. pistons wont either unless you raise the compression. cams will give you some increase.
If you really want power, boost it or add a shot of nitrous.
post Apr 16, 2013 - 9:08 PM
Syaoran
Joined Jan 4, '12
From US
There's no aftermarket valve springs for the 5S that I'm aware of. There's only 2JZ springs which need the bottom of the spring machined to fit into the stock spring seats. You could use stock or 2JZ retainers.
As for pistons, unless you up the compression like Smaay mentioned, you're not going to get more power out of a forged set. The cams are a good upgrade regardless of N/A or F/I.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Apr 19, 2013 - 12:48 PM
playboymma
Joined Jan 7, '11
From Mena, AR
i want the internals to survive the cam upgrade. i was looking for about 200 NA whp, but after research, that's not possible. i'm not juicing or boosting my daily. so i'd just like to have a budget build with a little pep in its step to tool around town in.
post Apr 19, 2013 - 3:48 PM
Syaoran
Joined Jan 4, '12
From US
What do you mean by "internals"? It's not like you need pistons or rods for better cams. You'd only need rods for a higher rev limit.
post Apr 28, 2013 - 10:24 AM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
I have a set of JE Pistons. Stock bore and compression. needs new rings.
-Alex {](O_o)[}
Lo-Fi Version Time is now: June 22nd, 2026 - 8:22 PM
