Jan 22, 2004 - 7:09 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
how did you drill into the brake pedal? theres no way a drill fits at the angle you need to drill into it at.
-------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Jan 22, 2004 - 10:16 PM
Enthusiast ![]() ![]() ![]() Joined Oct 9, '02 From San Diego, CA Currently Offline Reputation: 0 (0%) |
http://www.autovation.net/articles/tech/Pedal/tech.htm ... you have to push the brake pedal down and a wood block behind it helps, its an awkward position but very much possible to do.
Jan 22, 2004 - 10:30 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
I took my pedals completely out.. that worked for me.. no more time cramped under the dash than nessary
-------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Jan 22, 2004 - 10:47 PM
the brake pedal doesnt push down far enough. i did it for the clutch, the brake doesnt push down. i printed those instructions out.
Jan 23, 2004 - 12:03 AM
Enthusiast ![]() ![]() Joined Dec 20, '02 From OKC Currently Offline Reputation: 0 (0%) |
is your car on if it isnt then your breaks will not push down as far so if you havent try it that way should work better for you
DREW |
| Lo-Fi Version | Time is now: September 15th, 2026 - 2:33 AM |
