> Engine noise/smoky start up, Help me out
post Jun 30, 2013 - 3:51 PM
Rumper
Joined Jun 8, '13
From ontario canada
So I just got a 1994 celica gts, I've owned a 5gen before and had a lot of fun with it, so I chose to buy another celica, drove an hour or two away and picked me up a nice green gts, it needs some minor bodywork and some engine work but I don't really care as its not my dd, after bringing it home and putting a new distributor, plugs, wires, timing belt and water pump it has been running good (it has 215xxxkm on it) I've noticed when I'm off the throttle there seems to be what I think is valvetrain noise... Anybody heard of this? Also I'm getting some blue smoke upon start up.... Any help would be hugely appreciated.
I also have a 3rd gear synchro problem which I hear is common but I've came up with a way to shift that doesn't grind!
Thanks from ontario Canada!!
post Jun 30, 2013 - 5:16 PM
richee3
Joined Jun 29, '08
From Denver
The 5S is known to shoot a puff of smoke on startup. If I recall correctly, it's the valve seals. I wouldn't worry too much about it, depending on how much it smokes when you start it up. The 3rd gear syncro issue is pretty common, and some Pennzoil Syncromesh in the transmission seems to be a decent cure 9 times out of 10.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jun 30, 2013 - 7:11 PM
Rumper
Joined Jun 8, '13
From ontario canada
QUOTE (richee3 @ Jun 30, 2013 - 5:16 PM) *
Awesome, thanks man, you have any ideas about the valvetrain noise? I have another motor that I'm going to build up but until then I'm driving with the stockie
post Jul 1, 2013 - 2:41 AM
b22ri22an
Joined Jun 2, '10
From Davenport, Florida
bucket and shim system for valve clearance, have it checked and adjusted.... if you have to much of a gap on any of the cam lobes to the shim the valves can get quite noisy.
post Jul 1, 2013 - 7:50 PM
trdproven
Joined Aug 2, '05
From Guam
if you don't got a head gasket problem, you will smoke at startup, (valve seals) i puff puff pass all the time.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: August 31st, 2026 - 4:25 AM
