> Suspension and Brake Questions
post Jul 30, 2013 - 8:47 PM
1994Celica
Joined Aug 5, '09
From West Texas, USA
I need some suggestions on some suspension and brake parts. I already have the struts picked out that I want. I'm getting KYB GR-2's, however I'm still deciding on polyethylene vs rubber bushings. Anybody on here have poly bushings and can describe how hard the ride is? I also need suggestions on which pads and rotors to get for my brakes.
JDM Part King
post Jul 30, 2013 - 9:01 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
good pick with the GR-2's
the bushings are a good mod. You maybe might not feel to much of a difference without supporting mods (sways/poly enginemounts/etc)
I wouldnt go out of your way to replace them. Unless if you had planned on replacing them bushings (if theyve gone bad) or you are bored haha.
Brake upgrades. I suggest EBC all around. Green stuff pads would suit your needs for spirited driving and some occasional track use.
Hawk HPS pads (i think they are called) are also a popular pad
EBC slotted rotors are great for front rotors. And a decent set of Brembo blank rotors are sufficient (paint the rotor hats so they dont surface rust!!)
I have front EBC rotors for sale if you want a cheap used set. Also some red EBC pads which are a tad bit more for track use, but bite just as much if not more than the greenstuff pads. PM me if you want em
Also grab some stainless steel brake lines. They work WONDERS for pedal pressure
エキサイティングカーレーシングチーム!
post Jul 30, 2013 - 9:14 PM
1994Celica
Joined Aug 5, '09
QUOTE (Tigawoods @ Jul 30, 2013 - 9:01 PM) *
I plan on doing swaybars(not sure what to get on those too), and I do plan on replacing the bushings. Ill check out the pads and rotors, thanks.
JDM Part King
Lo-Fi Version Time is now: August 22nd, 2026 - 7:01 PM
