3 Pages V   1 2 3 >
> Wide front arches.
post Sep 9, 2013 - 7:14 AM
yellowchinaman
Joined Aug 11, '08
From London
Only 20mm wide and is going to look subtle like OEM.
Why only 20mm??? Well here's an explanation from the GT4OC.
"There are several major benefits to this, for many people the main benefit would be fatter looks - but thats not the only thing. In stock form the rear arches have space to take much wider or bigger offset wheels than the fronts, with a 4wd system you really want to run the same width wheels all round so most people resort to running spacers on the rear to make it look better with the deep rear arches. The problem with this is that the rear track width is deliberately narrower than the front on the GT4 in order to help counter understeer, by making the rear track wider without similar increases on the front you will be increasing the car's understeer tendencies. This might not be noticeable on the road to many but if you start pushing it hard on track it can be seen alot more. Also there is the added benefit of removing a little weight from the heavy front end of the car (every little helps!), and replacing your rusty and dinged original wings with mint new ones.
Obviously the other great benefit is it will means a whole load more choice of wheels becomes available, so anyone with dreams of 10" deep dish JDM bling could be in luck."
So here's how we being.
First off we make a template using replica arches fixed exactly 20mide from the top edge of the arches.
Notice how these replica arches have the lines to retain continuity.
As you can see it's very subtle yet significant
Next off after I've sealed the arches with masking tape to ensure no leaks I'll start with the expanding foam.
TBC...
post Sep 9, 2013 - 11:02 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Subscribed. I may be in the market for these if you decide to mass produce.
~bloodMoney
post Sep 9, 2013 - 11:19 AM
Shigexile
Joined Oct 30, '03
From IL
ditto
post Sep 9, 2013 - 11:33 AM
yellowchinaman
Joined Aug 11, '08
From London
QUOTE (bloodMoney @ Sep 9, 2013 - 12:02 PM) *
This is being done as there is a demand for the GT4's to balance it's stance with it's rears.
They will be going into production next week.
Anyway here's the fun part with 2 part expanding poli foam. (Not the one's in the can)
So I started by sealing the gaps with masking tape to try to contain as much liquid foam as I can.
Otherwise it'll just leak out and go all over the floor before it expands.
2 part foam. This allows me to control the expansion and bubble density rate. There is a secret to proportional mix and also timing as to when to pour for different stages.
These two tape strips prevent the guided arches from pulling out any further when the foam expands. Without them, you'll have uneven widths.
Dont worry about making a mess
After the first filling had fully set, I can then remove the supporting tape and start the build up as high as I can for the blending.
Small layer by layer is built on top of each other.
once that's done and set after an hour or so, I started the rough carving
Then using 80 grit and sanding block, I started taking it back to get a smooth curve.
The foam needs to be taken back a few mm's more or deeper then what you initially want. This is because of 2 things.
1: Fibreglass filler is needed to be applied before fine filler so you can't have any foam being exposed.
2. The filler work wont happen till tomorrow because the foam may still expand.
As you can see I'm going for a subtle OEM look. Already it's looking more like a match with the rear arches.
Over the next few days I'll be doing lots of filler work skimming over and over again till it's even on both sides.
Once done, I'll quick prime it and smooth it down. Then we'll start with the composite moulds for mass production.
ETA on this wide front arches will be another 2 weeks.
This post has been edited by yellowchinaman: Sep 9, 2013 - 2:10 PM
post Sep 9, 2013 - 12:48 PM
This is looking very proper!
post Sep 9, 2013 - 9:47 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
exciting!!
post Sep 9, 2013 - 10:18 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
AUUUUGHHHH stop making me spend more money on my car!!!
エキサイティングカーレーシングチーム!
post Sep 10, 2013 - 3:03 AM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (Tigawoods @ Sep 9, 2013 - 10:18 PM) *
2001 Miata LS 5-speed
post Sep 10, 2013 - 3:20 AM
rentaspace
Joined Sep 23, '12
From Australia
QUOTE (Box @ Sep 10, 2013 - 4:03 AM) *
post Sep 10, 2013 - 5:54 AM
yellowchinaman
Joined Aug 11, '08
From London
QUOTE (rentaspace @ Sep 10, 2013 - 4:20 AM) *
hahaha!
post Sep 10, 2013 - 6:43 AM
Again, I love that you're putting out such a quality product for such a niche market - truly an enthusiast. I say so especially since you're letting us through the process of creation.
This post has been edited by SwissFerdi: Sep 10, 2013 - 6:43 AM
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Sep 10, 2013 - 8:32 AM
celicaGT96
Joined Aug 14, '05
From Corpus Christi Tx
Maybe I missed it.. but how will these be mounted up the the fenders? Once in production..
post Sep 10, 2013 - 11:00 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
Where's the like button? I've got zero offset wheels which fit perfect in the rears but up front I had to do fender fenessing to get them to work as well as some pulling. These might do well for me.
post Sep 10, 2013 - 4:39 PM
yellowchinaman
Joined Aug 11, '08
From London
Thanks
These are not add ons but actual front fender replacements.
Many are rusty and battered so you just remove and replace with these wide onese as they fit the same.
In face the ones kn my car now which im working on are fibreglass ones we currently sell.
post Sep 10, 2013 - 7:33 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (yellowchinaman @ Sep 10, 2013 - 5:39 PM) *
Thanks
Wouldn't it be more cost effective to have them as add-ons? I mean, shipping is going to be a major killer for anyone that is interested + the price of the actual parts.
post Sep 10, 2013 - 8:09 PM
kloudkicka
Joined May 8, '04
From Winnipeg
very interesting, hmmmm, cant wait to see how they look completed
post Sep 10, 2013 - 8:45 PM
celicaGT96
Joined Aug 14, '05
Very interested! Just worried about shipping as well..
post Sep 10, 2013 - 9:59 PM
max-elle
Joined Jul 15, '07
From Italy
Very very interesting, so you will made entire fenders?
If so why don't you think also if could be possible to integrate "fender side vent"?
I say so because only a few are available and nothing really beautiful.
Instead I'd like to see something elegant like nissan gtr
or opel gt (saturn sky)
or jaguar xk or cf concept
wide arches + side vent = would be amazing <3
This post has been edited by max-elle: Sep 10, 2013 - 11:13 PM
post Sep 10, 2013 - 10:56 PM
celicaGT96
Joined Aug 14, '05
#repost sorry#
This post has been edited by celicaGT96: Sep 10, 2013 - 10:57 PM
post Sep 11, 2013 - 3:57 AM
yellowchinaman
Joined Aug 11, '08
From London
Yes postage will cost more but an enitire fender is better then add on.
With add on youll still have the origional arch which will catch when you space the wheels out or have it lowered.
We have thought about vents butnits too much of a hit and miss in choice so we decided against it. Being made of fibreglass you can always blend your own on easily.
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: September 1st, 2026 - 2:26 AM
