> Replacing tail light bulbs
post Sep 14, 2013 - 1:18 PM
6thcelestial
Joined Dec 29, '08
From midwest
Is there a way to disconnect all the bulbs further back in the wiring so I can pop them all into the tail light itself away from the car, and then reconnect the wire? Maybe a dumb question, but it's kind of tricky trying to hold the actual tail light unit while trying to twist all the bulbs in. I did not see an area where all the wire came into one lead for me to disconnect, but thought I would see if anyone knew. Thanks
This post has been edited by 6thcelestial: Sep 14, 2013 - 1:19 PM
post Sep 14, 2013 - 1:23 PM
rivs
Joined Jan 27, '08
From Mass
QUOTE (6thcelestial @ Sep 14, 2013 - 1:18 PM) *
Yeah, the main plug for each light is in the trunk. It's about 6 inches from where it goes into the car. It's is pretty easy to get to. You just need to remove some of the trunk plastics.
post Sep 14, 2013 - 2:24 PM
6thcelestial
Joined Dec 29, '08
From midwest
Thanks, that is a big help. Is it just a single snap connection at one point?
post Sep 14, 2013 - 2:35 PM
rivs
Joined Jan 27, '08
From Mass
Yeah it's just one plug per side.
post Sep 14, 2013 - 3:17 PM
6thcelestial
Joined Dec 29, '08
From midwest
QUOTE (rivs @ Sep 14, 2013 - 2:35 PM) *
Thanks Rivs. I am not at the car right now where I've got it taken apart, but is the connection right behind both side panels, and do you remember what color they are? Once disconnected, I can take the whole tail light unit out , bulbs and all, right?
post Sep 14, 2013 - 3:49 PM
rivs
Joined Jan 27, '08
From Mass
Yeah you'll be able to pull the whole light out. Just the rubber grommets on the wire will be left. I believe the connector was white.
post Sep 16, 2013 - 9:16 AM
6thcelestial
Joined Dec 29, '08
From midwest
Thanks Rivs. Hopefully getting out to the car today to finish up. I remember the opening for the wires to be pretty small. How do you get the wires/connector out through it?
post Sep 16, 2013 - 9:20 AM
rivs
Joined Jan 27, '08
From Mass
QUOTE (6thcelestial @ Sep 16, 2013 - 9:16 AM) *
Once you remove the rubber grommet, the hole is big enough for the wire and connector.
post Sep 16, 2013 - 10:54 AM
6thcelestial
Joined Dec 29, '08
From midwest
Thanks Rivs. I am guessing that the grommet goes back in pretty easily, and stays put afterwards.
Lo-Fi Version Time is now: September 12th, 2026 - 3:57 AM
