> timing belt issues, 3sgte gen 2
post Nov 10, 2013 - 12:34 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
ok so i have my car almost back together. i have cylinder 1 at tdc and my cam gears on the mark. i get the tensioner in and then turn it over with a wrench to double check my work. it all check out, but when i crank the car with the key my belt is off by a few teeth. the belt seems snug, no slack in it. but the tensioner has been off a few times. should i buy a new tensioner, or do i have other issues? thanks.
post Nov 10, 2013 - 3:52 PM
Sounds like a tensioner issue to me.
post Nov 10, 2013 - 3:57 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
i think so too. im gonna order one to be safe. it is running now with about a tooth off.
post Nov 11, 2013 - 12:20 AM
it might be the timing belt. have you checked it for missing groovs.
post Nov 11, 2013 - 10:16 AM
I had the same problem when I did mine. The issue was that I was using those little notches on the cams as a guide, like everyone says to do. This is a mistake, because its hard to judge when they are perfectly straight.
You should really go by the teeth on the cam gears.
Use a paint pen to mark where those teeth marks are directly on the gear. Then use the pen to mark where the belt thinks tdc is. After you do this, it will be very clear how far off you are.
I'm pretty sure joe bought a new tensioner when I did his belt. All of the pulleys are new too. You should be able to just reuse everything.
This post has been edited by lagos: Nov 11, 2013 - 10:16 AM
post Nov 11, 2013 - 6:14 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
art my problem is i do the timing everything is snug. turn it over by hand and it is good. then i turn the car on the the belt jumps a few teeth. all my components are new.
post Nov 11, 2013 - 6:48 PM
QUOTE (garin @ Nov 11, 2013 - 6:14 PM) *
Do you see a lot of slack in the belt as the engine is running?
post Nov 11, 2013 - 6:53 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
advance the timing by a few teeth and when you crank it, itll jump back to where you want it to be
エキサイティングカーレーシングチーム!
post Nov 11, 2013 - 6:57 PM
QUOTE (Tigawoods @ Nov 11, 2013 - 6:53 PM) *
post Nov 11, 2013 - 7:01 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (lagos @ Nov 11, 2013 - 6:48 PM) *
no i do not. im not sure what is going on. i ordered a new tensioner to be on the safe side. i have my teeth marked with a paint pen too. gonna give it another go this weekend. i think it is what you said art, or the intake side has a lot of slack... thanks for the input. btw mike i drove through columbia a few weeks ago... lol
post Nov 11, 2013 - 8:04 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (garin @ Nov 11, 2013 - 7:01 PM) *
エキサイティングカーレーシングチーム!
post Nov 12, 2013 - 9:06 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (Tigawoods @ Nov 11, 2013 - 8:04 PM) *
Lol it was like at 1 in the afternoon on a Monday... Anyways ordered a new tensioner. Gonna give this another go.
post Nov 16, 2013 - 4:39 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
i got it timed correctly. not sure what the deal was.. lol the paint pen trick is a good one!
1. make sure all your gears are lined up to the correct timing mark (use the paint pen to help)
2. make sure the belt is snug in the gear teeth
3. when you pull on the pulley to slide the tensioner in make sure nothing moves and the belt is secure in the gears
4. install the tensioner and hand spin the crank to double check your work
post Nov 16, 2013 - 5:17 PM
95st-celica
Joined Mar 29, '07
From Philly
i didnt have any problems when i put mine on!
HA!
just kidding garin...you'll get it figured out
1988 Dodge Aries K (sold)
post Nov 16, 2013 - 6:50 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
it is on joe! car stalled out and doesnt want to start now. it cranks very strong. i have the battery charging now. it is a fuel or vacuum problem i think.
post Nov 16, 2013 - 7:45 PM
QUOTE (95st-celica @ Nov 16, 2013 - 5:17 PM) *
HA!
QUOTE (garin @ Nov 16, 2013 - 4:39 PM) *
Glad it helped you out. Its really the only way to do a belt on these engines.
Lo-Fi Version Time is now: August 23rd, 2026 - 6:31 AM
