> OBD2 port question, Is it possible to reschedule locate
post Feb 4, 2014 - 6:53 PM
toyota123
Joined Jan 13, '12
From Georgia
Just got home with my celica and I was going to hook up my bluetooth obd2 module and I can't find the port so my question is can it be relocated or is it more likely that the motor was swapped with and obd1
Thanks in advice guys
97 Celica GT liftback DD/ project
96 corolla back up DD
post Feb 4, 2014 - 7:45 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (toyota123 @ Feb 4, 2014 - 3:53 PM) *
Obd2 ports are usually under the steering wheel/dash. Like your head under where the gas pedal is at and you'll see it.
post Feb 4, 2014 - 9:57 PM
toyota123
Joined Jan 13, '12
From Georgia
Right just like on the other 97 I have I just haven't been able to locate it so I'm trying to figure out the likelihood of it being re located, removed or if the previous owner swapped motors and went with an obd1 which seems like it would be more trouble than its worth
post Feb 5, 2014 - 12:29 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (toyota123 @ Feb 4, 2014 - 6:57 PM) *
Is it a year 96+?
post Feb 5, 2014 - 1:22 AM
its highly doubtful that it was swapped back to ODBI, and even if it was there would be no point in removing the port.
post Feb 5, 2014 - 9:27 AM
toyota123
Joined Jan 13, '12
From Georgia
All the paperwork I have says it a 97 all the obvious vin numbers match and according to auto check it's a 3 owner car that has never been in an accident. I can't see any reason why a car with as much care as this one has had would have needed a motor. I'm hoping it's just tucked away because I live in an emissions County and they have to run that through the obd2vif it doesn't have one I'll have to add it or have a car that I can't register
post Feb 5, 2014 - 3:25 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (toyota123 @ Feb 5, 2014 - 6:27 AM) *
Maybe the previous owner kicked it and it broke off so its hanging somewhere inside the panel? Stick hour head in there again with a flash light.
post Feb 5, 2014 - 9:50 PM
toyota123
Joined Jan 13, '12
From Georgia
I finally found it. It was unmounted and tucked away inside the center console I had to take the bottom of the dash apart to trace all the wires and also noticed that the is a Gps device installed that I'll have to figure out to disable it
Lo-Fi Version Time is now: September 15th, 2026 - 6:06 PM
