Apr 9, 2014 - 12:49 PM
Enthusiast ![]() ![]() ![]() Joined Oct 3, '10 From Lansing, MI Currently Offline Reputation: 2 (100%) |
Hey everybody,. I've been reading on here, toyota nation, and the MR2 forums that some people are now swapping in the E351 from a 4cyl Camry rather than the E153 transmission to get the taller gear ratios.
Apparently E351 Transmissions are plentiful in my area and sell for around 300-400 however, e153 transmissions are few and far between 400-750. So anyone have the info on this transmission? Does it bolt to the 5F-SE, I'm guessing so how about a candidate for the 1mz/3mz hybrid swap,. is the torque of that combo going to blow this to pieces? and with the E351 I'm guessing it's the same axle setup as the E153? E351 is from (06-09 Camry XV40), (08-14 xB), (09-12 Corolla XRS), (2009-2013Toyota Matrix XRS) Here a quick comparison of S54 Stock,. versus E153, versus E351 ratios,. S54 1st 2nd 3rd 4th 5th Reverse Final 3.285 1.960 1.322 1.028 0.820 3.153 4.176 E153 1st 2nd 3rd 4th 5th Reverse Final 3.230 1.913 1.258 0.918 0.731 3.545 3.933 E351 1st 2nd 3rd 4th 5th Reverse Final 3.538 2.045 1.333 0.972 0.731 3.583 3.944 Seems like the E351 would be geared much better for the V6 swaps,. but will it hold up to the power and torque? Anyone swapped one in? |
Apr 9, 2014 - 5:35 PM
I don't think the E351 will bolt up properly
Apr 9, 2014 - 5:51 PM
Apr 10, 2014 - 11:00 AM
Here is the "Don't use the E350/1" post
Please, do not confuse the E35x for the E153. The E35x has a smaller, less robust differential than the E153 and a completely different transaxle case. |
| Lo-Fi Version | Time is now: August 30th, 2026 - 5:58 PM |
