> Cold 3s-ge wont run
post Apr 20, 2014 - 8:37 AM
Rodzy
Joined Apr 18, '14
From Slovenia
Hello guys.
I have a little problem with my 1996 ST202. When car is cold and outer temperatures are under 10 degress celsius (50 fahrenheit) car normally start and runs aroud 800-900 rpm. Then I drive a little, but when I stop at first traffic lights, engine dies and dificulty starts again and doesn't want to run on idle. After some more driving, when engine warms up, everything is back to normal. What may be the problem, air temperature sensor maybe? I have no idea how cold start system works on this car, but when engine is cold it should run around 1500 rpm until it warms up.
post Apr 20, 2014 - 1:53 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Recently another member had similar problems. His issue was a bad vvti solenoid. lol.
post Apr 20, 2014 - 4:57 PM
Rodzy
Joined Apr 18, '14
From Slovenia
I don't think this is the problem because I'm talking about 3rd gen 3s-ge without vvti biggrin.gif
post Apr 20, 2014 - 5:52 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Rodzy @ Apr 20, 2014 - 2:57 PM) *
Ok. You didn't mention what gen it was so I thought it was the beams since you had st202. Lol.
post Apr 23, 2014 - 7:50 AM
Rodzy
Joined Apr 18, '14
From Slovenia
Question: If I have faulty water temperature sensor, could water temperature gauge work properly, but not system for cold start?
post Apr 23, 2014 - 12:02 PM
mi645
Joined May 23, '12
From northridge,CA
check isc, take the entire thig off ur throttle body, make sure u dont take it out with the 2 screws infrpnt of the sensors make sure to take out the wntire thing from the bottom of the theottle body theres a gasket in there, make sure u clean the valve with brake cleaner and try ur engine them.
Lo-Fi Version Time is now: September 12th, 2026 - 11:54 AM
