May 15, 2014 - 12:47 AM
Enthusiast Joined May 10, '12 From Mesa, Arizona Currently Offline Reputation: 0 (0%) |
Hi everyone, I was an idiot today and snapped one of the oil pan bolts on my 1994 ST. The bolt head sheared off at the pan leaving nothing to grab onto to remove the broken shank. Short of removing the whole pan and getting the bolt out that way, what would you guys recommend?
May 15, 2014 - 1:08 AM
http://www.harborfreight.com/12-piece-scre...-set-40349.html
Doesn't necessarily have to be that kit, but a screw extractor will get the job done. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
May 15, 2014 - 1:18 AM
Any idea what size those bolts are? I know the head size is 10mm, the shank looks to be something like 5 or 6mm. Not sure what the thread size is though.
May 15, 2014 - 1:42 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) |
Usually it goes like:
10mm head: M6 bolt 12mm head: M8 bolt 14mm head: M10 bolt 17mm head: m12 bolt 19mm head: m14 bolt -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
May 15, 2014 - 3:09 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) |
Drill out the center of the bolt and use an extractor tool. It will screw into the hole reverse threaded, so eventually it bottoms out and starts to turn the bolt counterclockwise
My oil dipstick tube was snapped off in the block, I got it out like a piece of cake with an extractor and that thing is a bear to get out even when it isnt broken off in the block This post has been edited by Special_Edy: May 15, 2014 - 3:11 PM |
May 15, 2014 - 10:17 PM
Enthusiast ![]() Joined Aug 31, '13 From Wyoming Currently Offline Reputation: 0 (0%) |
tack weld something of smaller diameter onto it and unscrew it?
May 16, 2014 - 10:38 AM
the extractor method works good. what I usually do is start with a small drill bit and work my way up until there is nothing left of the original broken bolt. ill run a tap in the hole to clean up the threads. done!
| Lo-Fi Version | Time is now: September 13th, 2026 - 1:07 PM |
