> apexi avcr help
post Jun 29, 2014 - 12:50 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
installed an avcr today. everything seems to be wired properly. throttle reads open and closed on the unit, however the engine flutters at 2000 rpms. I'm not sure what is wrong. air fuel is rich and vacuum doesn't really move from 22 in/hg. any input is appreciated
post Jun 30, 2014 - 2:22 PM
AVCR is a boost controller, not a tuner like the SAFC.
post Jun 30, 2014 - 3:39 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
I am very well aware of this! That is why I am asking. My car seems to be in a limp mode after the install.
post Jun 30, 2014 - 3:43 PM
Nial
Joined Aug 25, '08
From England
What settings did you use?
My Facebook GT4 Build page.
https://www.facebook.com/groups/GT4Rebuild
post Jun 30, 2014 - 6:32 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
Didn't even get that far. I plumped it as follow.
1. Turbo compressor wheel to "no" port on solenoid
2. Wastegate to "com" port
3. Plugged the wastegate to vsv port
4. Jumped the green boost solenoid (back of manifold) on the vsv system
5. Apexi map sensor is tapped into boost gauge line on intake manifold
Wiring
1. Red is power into ignition fuse
2. Green and black to body ground
3. Purple into injector 1 on the ecu (plug e4 pin 12)
4. White to speed sensor on the ecu (plug e6 pin 9)
5. Gray to vta (plug e5 pin11) pink and black; goes to tps
Did I do anything wrong with install?
post Jul 1, 2014 - 12:27 AM
Nial
Joined Aug 25, '08
From England
Everything with the install looks okay apart from possibly the earth, they have to go close together on an earth wire to the ECU, something like within two inches of each other but not soldered together, and pretty close to the actual ECU.......if that's how you did it then that's fine.
But, you need to set it up before you run the car.
I don't know if you can follow this link.
http://www.gt4oc.net/forums/download/file.php?id=19999
I will try and copy And paste it here later on today if nobody else does, it will give you all the settings you need for a basic set up, it will need further tweaking to get it perfect for your car etc but it's a good start.
This post has been edited by Nial: Jul 1, 2014 - 12:30 AM
post Jul 1, 2014 - 5:26 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (Nial @ Jul 1, 2014 - 1:27 AM) *
i might have to look over my grounds... and please do copy that link here!
post Jul 1, 2014 - 7:10 AM
Nial
Joined Aug 25, '08
From England
These should get you underway, they will need adjusting to suit your car.
Apex-i AVC-R settings for 0.9 Bar and 1.1 bar
BASIC SETTINGS
Setting [A] 0.9 Bar
Boost /Duty Cycle
Bst = 0.90kg/cm2
Duty = 52%
NE Point
NE1 = 3000
NE2 = 3500
NE3 = 4000
NE4 = 4500
NE5 = 5000
NE6 = 5500
NE7 = 6000
NE8 = 6500
F/B Speed
1S = 5
2N = 5
3R = 5
4T = 5
5T = 5
Learn Gear
1S = x
2N = x
3R = x
4T = x
5T = x
Start Duty
1st = 5%
2nd = 1%
Setting [B] 1.1 Bar
Boost /Duty Cycle
Bst = 1.10kg/cm2
Duty = 60%
NE Point
NE1 = 3000
NE2 = 3500
NE3 = 4000
NE4 = 4500
NE5 = 5000
NE6 = 5500
NE7 = 6000
NE8 = 6500
F/B Speed
1S = 5
2N = 5
3R = 5
4T = 5
5T = 5
Learn Gear
1S = x
2N = x
3R = x
4T = x
5T = x
Start Duty
1st = 6%
2nd = 2%
Etc settings
Car Select
Cyl = 4
Spd = 5
Throttle = / (arrow pointing up to the right)
Sensor Select
Number one (1)
Gear Jdge
1st = 120
2nd = 075
3rd = 050
4th = 035
5th = 025
N/S = 255
Graph Scale
BS = 2.0kg/cm2
Ne = 8000 RPM
Sp = 300km/h
Monitor
2 Channel
1 Bst
2 Rev
You can set the Monitor to whatever you want and display any information you choose from 1 to 4 different types of information
post Jul 1, 2014 - 8:39 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
I didn't see a "spd 5" option... Any words of wisdom? This is for a gen ii.
post Jul 1, 2014 - 8:49 AM
Nial
Joined Aug 25, '08
From England
If there isn't an option for it, then I guess you can leave it.
post Jul 1, 2014 - 8:57 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
QUOTE (Nial @ Jul 1, 2014 - 9:49 AM) *
There is a spd 2,4,6 I think.
Thanks for the help I'll keep you pisted
post Jul 1, 2014 - 11:09 AM
Nial
Joined Aug 25, '08
From England
Good stuff, I look forward to your next pist!
post Aug 23, 2014 - 8:50 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
Everything seems to read and respond properly. The unit loses memory after the car is shut off. Might need to tap into another power source...
post Aug 24, 2014 - 2:36 AM
Nial
Joined Aug 25, '08
From England
QUOTE (garin @ Aug 23, 2014 - 9:50 PM) *
It shouldn't! Mine keeps it's memory even after the battery has been completely removed for servicing.?
post Aug 24, 2014 - 10:14 AM
garin
Joined Aug 12, '07
From Lancaster, Pa
To save the setting I must go to the "7. Initialize" and select "yes" with the next button correct?
post Aug 24, 2014 - 11:25 AM
Nial
Joined Aug 25, '08
From England
QUOTE (garin @ Aug 24, 2014 - 11:14 AM) *
Can't remember, it's a while since I set one up....try it and see what happens?
post Aug 24, 2014 - 1:43 PM
garin
Joined Aug 12, '07
From Lancaster, Pa
figured it out! "initialize yes" resets it to factory settings. thanks nail for the numbers i think I'm running around 12 lbs now.
post Aug 24, 2014 - 4:23 PM
Nial
Joined Aug 25, '08
From England
No bother bud, glad it's all fixed and working.
Lo-Fi Version Time is now: May 17th, 2026 - 2:12 PM
