Dec 31, 2014 - 12:04 PM
![]() Enthusiast ![]() Joined Jul 21, '10 From Northern NJ Currently Offline Reputation: 1 (100%) |
For everyone who is looking for an emissions compliant bolt-in catalytic converter, we have a solution for you! Made in house at Prime, we offer our 3" Downpipe w/ Integrated Catalytic Converter. We cut the top off the stock Gen4 cat converter and weld on 3" tubing and a magnaflow catalytic converter . This is a direct bolt on for a Gen4 or Gen5 powered MR2 with any MR2 turbo exhaust system! This 3" downpipe clears the A/C compressor.
* Quality and fitment that you've come to expect from PRIME PERFORMANCE! Proudly 100% MADE IN THE USA! * Does not come with hardware, gaskets, or support bracket. SPECS: These MagnaFlow universal spun catalytic converters utilize the revolutionary new catalyst technology. Using new manufacturing technology, MagnaFlow fabricates each converter body from a single CNC-formed and laser-welded tubular section, which is then spun into a round converter body shape. The MagnaFlow universal spun catalytic converters are literally manufactured around the catalyst, which is securely tucked inside and necks down to thicker-gauge material at the inlet/oulet for maximum durability. AIR Tube: No California Legal: No Converter Case Material: Stainless steel Converter Substrate Material: Metallic substrate Heat Shield: No Converter Style: 3-way Buy it here: http://www.primemr2.com/store/c9/GEN4_GO-FAST_Parts%21.html -------------------- PRIME Performance 862-258-3346
Check out our store and services: www.PRIMEMR2.com |
| Lo-Fi Version | Time is now: September 1st, 2026 - 6:57 AM |
